Gigabyte B650M Aorus PRO AX (rev. 1.0) EFI - Adaptable to Gigabyte B650 boards
I just updated to OpenCore 0.9.4 and Ventura to 13.5, no issues until now. The EFI post was updated with it.
Reactions: svan71
Sonoma go or no go?
Sonoma go or no go?
Go but with the BCM94360NG wifi won't work, bluetooth will, without using OCLP (openCore Legacy Patcher. Intel Cards work with the new Preview 5 Airportitlwm.kext as does Bluetooth.
I tried but she hung on first reboot stuck on the Apple Logo. I'm on 0.9.5 and looking for a solution.
IN your config.plist under Misc/ Security what setting is SecureBootModel set to? I had to change to "Disabled" to get it working, also I'd change to verbose mode to see if there are any clues as to where its stops.
Nah, it was my outdated kernel patch. All is good now.
Reactions: leesurone
Hi @leesurone. You can share your B650 aorus elite Ax EFI? with my EFI, I am unable to install Sonoma,The installation always fails. The same motherboard (B650 aorus elite ax).. sorry for the inconvenience
Here's my version using OC .9.6. I haven't triesd loading Sonoma with it being I use a Fenvi M2 card that Wifi would be disabled if I did.
Reactions: dekuyt
Thank u so much @leesurone. I`ll try
Let me know if you need my version as well, I am using 0.9.5, still need to update to the latest one.
I am not installing sonoma very soon due to the same issue leesurone talked about: the fenvi wifi...
Reactions: dekuyt
Did not work. Black screen after the apple logo. Ventura worked perfectly.
Can you share your EFI? I'll try it too
What did not work?
Reactions: dekuyt
What did not work?
Sonoma.. thank you very much. I'm going to install Ventura, it's working perfectly with your EFI
I just imported the MMIoWhitelist from my other EFI, and it worked.
@leesurone @jubarim Thanks for the help guys. Everything works perfectly now (Sleep, USB map) including Sonoma. I'm using the opencore legacy patcher and some kexts..so the wifi is perfect in Sonoma (Beta 14.3)
    EFI.zip
Very nice, just wanted to let you know your SMCRadeonGPU.kext is 0.3.3 and the latest is 1.3.0 and NVRAM->Delete 7C436110-AB2A-4BBB-A880-FE41995C9F82 : csr-active-config is duplicated.
Reactions: dekuyt
If you want to try Sonoma yours with patched Wi-Fi. Just need to run OCLP after install.
Thanks, I don't have that system anymore and made the decision to stay out of the OCLP pool a while ago. Appreciate the thought though. (y)
Thought I'd put my EFI up because this thread was very helpful. Aorus Elite AX B650 Rev 1.2, BIOS FC, 7700x, Opencore 9.8, running Sonoma 14.3.
I went ahead and started from scratch. Did my own MMIO discovery/testing, created SSDT's, etc.
It's been running stable for a couple days. I have no need for wifi or bluetooth so those aren't included.
Was using BIOS FA2, but FC seems to have a bit fewer bugs. Could just be me though.
Thanks for all the other postings and EFI's here.........
Reactions: jubarim
Good to hear that!
I have not moved to Sonoma yet, still in Ventura... I don't like the idea of disabling protections to use the native wifi/bt. But you never know, maybe later this year...
Updates:
22 March 2024
OS: Ventura 13.6.5
Opencore: 0.9.7
My build is not stable in sleep mode. Sometimes it just powers off and this week it's rebooting. Not sure what happened, maybe it's the latest Ventura 13.6.5 I updated to.
I just updated my BIOS to F22b, not sure if it will help, probably not, I will let you know.
