zxc2689963
135
92
28
Brand: Lenovo
Model: Legion 5 6th Gen
CPU: AMD Ryzen 7 5800h
Ram: x2 8GB 3200mhz ddr4
Display: 15.6 1080p 165HZ
Updated October 5, 2023
Problems solved:
Unresolved issues:
Failure to wake from sleep
Solution
Panic from Monterey 12.6
You need to install Python on your system for the Terminal commands to work.
Where and how have you installed Python? If you have undertaken a custom install then Terminal might not be able to find the app/command to start Python on your system.
Which make and model WiFi card? Most Intel and the natively supported Broadcom WiFi/BT cards work in macOS with the correct OC settings and kexts. But MediaTek, Realtek and Atheros cards don’t work.
Have you read the posts at the beginning of this thread, where common issues with the trackpad etc. are discussed?
Yes, I have read that I have enabled VoodooPS2Controller in order according to the instructions, and disabled ssdt-gpio. The touchpad still does not work
Did you try adding SSDT-XOSI.aml and the config.plist ACPI patch as a replacement, when you disabled the SSDT-GPI0.aml table?
Showing a partial screenshot of your kexts in OCAT is not really helpful. Post a copy of your EFI, without your Serial number being present in the config.plist. And a copy of your system IOReg.
I assume you are using a wired/wireless/BT mouse while trying to fix the trackpad.
I hope you can correct it for me. Thank you
Using the EFI you created will cause the system to become stuck and unusable
Stuck where? I'm unable to help without information.
Reactions: Edhawk
