zxc2689963
135
92
28
Brand: Lenovo
Model: Legion 5 6th Gen
CPU: AMD Ryzen 7 5800h
Ram: x2 8GB 3200mhz ddr4
Display: 15.6 1080p 165HZ
Updated October 5, 2023
Problems solved:
Unresolved issues:
Failure to wake from sleep
Solution
Panic from Monterey 12.6
Very nice work!
I wonder how long the battery life is under osx?
Actually, more than battery life, I'd like to know if it's possible to use vfio to pass a discrete graphics card (or even attach a physical disk, the laptop has two m.2 slots) directly to a virtual machine.
There is a project called osx-kvm, which I have been using as a working environment for about 2 years now, and I am very familiar with it. My daily work platform is a 3700x with 64G of RAM, plus two rx580 graphics cards, one assigned to the macos VM and one to the host Ubuntu. it's pretty smooth and stable.
I was thinking of using osx-kvm on this laptop so that I can work with Linux when I need long battery life, or have the option to boot physical disks or virtual machines when you need macos.
I'm considering whether to buy a Legion5 for this project, and I think it might be a little more worthwhile than an m-chip Macbook.
Reactions: kalkmann
Very nice work!
This is a game laptop, the battery should not be durable, I tried to install in Proxmox VE but failed, I am not very familiar with the method of such installation, hope to see your successful installation message, osx-kvm installation should solve the USB problem of this laptop
Same here. I tried Proxmox but I got stuck with a black screen. But in any case, it will not run as native, but it is as close to native as you can get via virtualization since is very close to metal
Running it in KVM with GPU Passthrough yields the same experience as bare metal, you won't notice the difference, but the laptop needs to support IOMMU for that, if anyone is interested, it can be tried.
Reactions: kalkmann
Tried with Proxmox all day today. After installing Monterey, passthroug the GPU, it gets frozen at "ioapic: version 0x11"
When I tried to passthrough the first USB controller, the XHC0, the computer would restart. With the 2nd controller I was able to use the keyboard to hit "enter".
My notebook is Legion 5-15ACH6A 82NW, Ryzen 5600H (six cores) with 6600M.
Can you send an image of where it stuck? Does it work without the GPU passed?
You probably weren't able to pass XHC0 because it's in IOMMU Group with another devices (usually SATA and Ethernet on AMD), this can be fixed with a custom Linux kernel, but I have no experience with this on Proxmox, I always used KVM manually on Arch.
Without the GPU passthroug it worked normal until I finished the installation, I was following this video from https://github.com/luchina-gabriel/OSX-PROXMOX
But after doing the passthroug the problems started, I edited the boot EFI several times, but nothing made it past the ACPI phase of the verbose boot.
As I'm not familiar with virtualization and won't be able to use the PS/2 keyboard/touch in this option, I'm going to go back to the "native" installation using yours EFI for the 8-core processor as base (which already worked here).
But what will be the solution to the USB ports of this laptop works without the GenericUSBXHCI kext?
Thanks for your answer.
My previous post released a kernel patch for Ventura support
I tested your EFI (adjusting patches for my processor and serials) to install Ventura. With or without GenericUSBXHCI.kext, it's in an infinite bootloop on 4th stage of the installation (before the graphical stage).
I have tested many times and found that Venture13.1 can boot successfully without GenericUSBXHCI.kext, even without customizing any USB port.
No USB ports are customized
In most cases, it will be stuck in the position below, which can be skipped only through continuous forced restart. As long as the startup is successful, the USB of the system is completely normal, no matter whether there is a customized USB port or not, I have no relevant knowledge to test why it is stuck randomly, I hope someone can give me some tips, thank you
Are you using this published EFI? Try disabling AmdTscSync.kext and configuring UEFI-Quirks-TscSyncTimeout (525000). Can you start the installer without GenericUSBXHCI.kext? What kind of wireless card are you using? I suspect that the probability of successful startup may be caused by the wireless card, of course, I have tried to remove the wireless card from the motherboard, but did not solve the problem, if replaced by BCM94360Z3/BCM94360Z4, what will happen, this is just my guess
Reactions: kalkmann
By disabling AmdTscSync.kext and configuring UEFI-Quirks-TscSyncTimeout (525000) + Patch from post #705 + GenericUSBXHCI.kext it was possible to finish the installation. I had no luck with GenericUSBXHCI.kext disabled.
My Wifi card is BCM94360NG, which I couldn't get to work in any MacOS system on this machine (in Windows 11 works).
Now I have Big Sur 11.2.3/ Monterey 12.6 running with extremegrief1's EFI (MacPro7,1) and Ventura 13.2 with your EFI (MacBookPro15,2). All depending on GenericUSBXHCI.kext
Thanks for everyone's effort so far! Hacking in AMD is really for the strongs.
Can you share the efi you are using now? Thank you very much. I have been trying to install it, but I have not been successful. Thanks again
I have a
https://www.lenovo.com/us/en/p/lapt...0000us?orgRef=https%3A%2F%2Fwww.google.com%2F with intel wifi card. Could I use your published EFI for ventura installation? What modification do I need? Thanks
Link to EFI: https://drive.google.com/drive/folders/1OpZXpjX-QrpjTvU7WBBljuxoQlBZeSjT?usp=share_link
My model is with Ryzen 5600H+6600M.
Remember to fill in the information in PlatformInfo > Generic
I didn't depend on working USB ports to start the installation (the Ventura image was already downloaded and I started the installation from Monterey).
Good luck!
Does your usb work? When I tried to install it, the usb still didn't work
As I mentioned in the answer, I didn't rely on USB ports for installation. I started the installation from Monterey (y)
The host can use usb in this version of the system, but I can not use it after installation, so I am curious how the host achieved this
