Exactly same symptom on my AQC107 on Gigabyte X570 Aorus Xtreme in 0.8.6, Monterey 12.5. Gladly would become a test subject for this troubleshooting.Interim Update #17:
- We are also starting to look into Aquantia 10GbE connectivity issues on Monterey and Ventura
- There may not be an easy answer for this, so we should temper our expectations
- I've installed the card in my X670E system, and the driver recognizes and attaches to the card in both Monterey and Ventura, but when an Ethernet cable is connected, both operating systems freeze
- This is emblematic of Vt-d issues
And it is also very good to be able to use the iPhone as a camera
Last login: Sun Nov 20 08:56:46 on console
fabio@Mac-Pro ~ % sysctl -a | grep -e tsc -e freq
kern.hv.clock.tsc_base: 203033896015
kern.hv.clock.tsc_clock_last: 0
net.link.fake.switch_mode_frequency: 10
net.pktsched.netem.sched_output_ival_ms: 1
net.pktsched.netem.heap_size: 2048
net.pktsched.verbose: 0
hw.busfrequency: 408000000
hw.busfrequency_min: 408000000
hw.busfrequency_max: 408000000
hw.cpufrequency: 3700000000
hw.cpufrequency_min: 3700000000
hw.cpufrequency_max: 3700000000
hw.tbfrequency: 1000000000
machdep.tsc.nanotime.tsc_base: 176339750178
machdep.tsc.nanotime.ns_base: 0
machdep.tsc.nanotime.scale: 1160800684
machdep.tsc.nanotime.shift: 0
machdep.tsc.nanotime.generation: 2
machdep.tsc.frequency: 3700004105
machdep.tsc.deep_idle_rebase: 1
machdep.tsc.at_boot: 0
machdep.tsc.rebase_abs_time: 47659339052
machdep.cpu.tsc_ccc.numerator: 0
machdep.cpu.tsc_ccc.denominator: 0
fabio@Mac-Pro ~ %
Last login: Sun Nov 20 09:00:39 on console
kern.hv.clock.tsc_base: 288764325769
machdep.tsc.nanotime.tsc_base: 263716912440
machdep.tsc.nanotime.scale: 1160800553
machdep.tsc.frequency: 3700004522
machdep.tsc.rebase_abs_time: 71274754068
fabio@Mac-Pro ~ %
@mariettosun,@CaseySJ :
I am trying in my system Official Opencore Debug and Shaneee OpenCore Debug PR
I use BootloaderChooser to have in my EFI all boot loaders I like to test in different situations.
This is a grab of debug txt:
and these are outputs of:
OFFICIAL:
Code:Last login: Sun Nov 20 08:56:46 on console fabio@Mac-Pro ~ % sysctl -a | grep -e tsc -e freq kern.hv.clock.tsc_base: 203033896015 kern.hv.clock.tsc_clock_last: 0 net.link.fake.switch_mode_frequency: 10 net.pktsched.netem.sched_output_ival_ms: 1 net.pktsched.netem.heap_size: 2048 net.pktsched.verbose: 0 hw.busfrequency: 408000000 hw.busfrequency_min: 408000000 hw.busfrequency_max: 408000000 hw.cpufrequency: 3700000000 hw.cpufrequency_min: 3700000000 hw.cpufrequency_max: 3700000000 hw.tbfrequency: 1000000000 machdep.tsc.nanotime.tsc_base: 176339750178 machdep.tsc.nanotime.ns_base: 0 machdep.tsc.nanotime.scale: 1160800684 machdep.tsc.nanotime.shift: 0 machdep.tsc.nanotime.generation: 2 machdep.tsc.frequency: 3700004105 machdep.tsc.deep_idle_rebase: 1 machdep.tsc.at_boot: 0 machdep.tsc.rebase_abs_time: 47659339052 machdep.cpu.tsc_ccc.numerator: 0 machdep.cpu.tsc_ccc.denominator: 0 fabio@Mac-Pro ~ %
Shaneee PR:
Code:Last login: Sun Nov 20 09:00:39 on console fabio@Mac-Pro ~ % sysctl -a | grep -e tsc -e freq kern.hv.clock.tsc_base: 288764325769 kern.hv.clock.tsc_clock_last: 0 net.link.fake.switch_mode_frequency: 10 net.pktsched.netem.sched_output_ival_ms: 1 net.pktsched.netem.heap_size: 2048 net.pktsched.verbose: 0 hw.busfrequency: 408000000 hw.busfrequency_min: 408000000 hw.busfrequency_max: 408000000 hw.cpufrequency: 3700000000 hw.cpufrequency_min: 3700000000 hw.cpufrequency_max: 3700000000 hw.tbfrequency: 1000000000 machdep.tsc.nanotime.tsc_base: 263716912440 machdep.tsc.nanotime.ns_base: 0 machdep.tsc.nanotime.scale: 1160800553 machdep.tsc.nanotime.shift: 0 machdep.tsc.nanotime.generation: 2 machdep.tsc.frequency: 3700004522 machdep.tsc.deep_idle_rebase: 1 machdep.tsc.at_boot: 0 machdep.tsc.rebase_abs_time: 71274754068 machdep.cpu.tsc_ccc.numerator: 0 machdep.cpu.tsc_ccc.denominator: 0 fabio@Mac-Pro ~ %
I think is not good to have applied this patch on AMD systems <> Zen4
Continuity Camera works on my Asus X670E Gene with a Fenvi FV-T919 (Broadcom WiFi/BT).Is this on one of yr Intel Hackintoshes or did you actually get Continuity Camera to work on yr X670E Hero mobo?
At least Zen2/3 APUs have been shown to benefit from the patch. The compute dies are the same, whether there is an iGPU or not.I think is not good to have applied this patch on AMD systems <> Zen4
All checks have passed.Uncrustify has passed!!
Interesting, the Gigabyte user just has a black screen, same for everyone on AM4, what GPU are you using?Continuity Camera works on my Asus X670E Gene with a Fenvi FV-T919 (Broadcom WiFi/BT).
I have a PowerColor RX 6800.Interesting, the Gigabyte user just has a black screen, same for everyone on AM4, what GPU are you using?
