ManuelB
218
82
28
7950X
@CaseySJ Ok thank you very much I'll try a bit in the meantime...just found out if I insert all the ssdt's the wifi works great, he now finds others too and I can activate and deactivate it...data in the attachment...it can be that I made mistakes when creating the USB map, I think yes, I will try to check them all again.....we are close to it....If we can still eliminate the error and get Bluetooth under control, you will see that but great
I'd suggest just making a proper UTBMap file, should be easier than all this...
@ManuelB Can you send the resulting UTBMap.kext when doing this:
Open USBToolBox.exe, type P to delete saved data if any, type D and then plug an USB drive into a port, wait a few seconds for it to appear in the console, unplug it, plug it in another USB port and repeat this for all of the USB ports, on the back and on the front. Then type B, type S then type T:14:255 to set the Bluetooth port's type to Internal and take a screenshot. Type K and send the screenshot along with the kext file.
I’ll take a look soon. It’s good that the SSDT method of port mapping is helping us find some unexpected problems. Let’s continue with that method for a little longer before switching to something else.
@XtremeXT
@ManuelB,
I've modified your UTBMap.kext based on the controller chart from yesterday.
You may backup the existing UTBMap.kext and try the attached version.
It is necessary to disable all of the SSDT-USB- files and the two USB kexts, then enable only the attached kext.
After rebooting, please post IORegistryExplorer file.
@XtremeXT
Looks fine but I did a mistake, you should have set port 40 as Internal not 14...
IF Casey's kext isn't working re-do it but type T:40:255 instead.
@CaseySJ here the ioreg and @XtremeXT I just need a moment do I have to connect them all again in the USB tool the same way?
Wonderful -- this shows the USB map fully activated. Previously we could not active USB Controllers D and E, which indicates some BIOS/ACPI problem because the same procedure works perfectly on Asus X670E.
For the UTBMap.kext I used the same port names and types as in the diagram below:
Please test sleep and wake, but set Settings --> Energy Saver --> Wake for Network Access --> off
Reactions: ExtremeXT
Don't re-do the USB map, seems like Casey's method worked. Follow what they said.
@CaseySJ Why do they need to disable that? The other user's Gigabyte motherboard works fine with default settings.
That option in settings, Wake for Network Access.
@CaseySJ & @XtremeXT Ruhezustand geht nicht richtig fährt runter aber beim hochfahren zeigt das Mainboard Fehler 11 ich hatte USB MAP eben nochmal neu gemacht dabei hat sich aber wohl der Usb Stick zerlegt. mit der Ioreg von eben habe ich mal das das Ilan geht und dann wieder nicht richtig. Ich hänge nochmals die Aktuelle Ioreg an
@CaseySJ I still have a ioreg here, now after the restart Wlan is fine again because I'm trying to go to sleep again...do the ioreg files differ?
Stop its Gone
On my Intel systems sleep is immediately interrupted. However, I just tried in on the Asus X670E Gene without disabling it, and sleep/wake still works.
When sleep does not work, I generally suggest turning this off to see whether it helps.
