ManuelB
218
82
28
7950X
@CaseySJ Many thanks for your help but unfortunately no...I'll get back to you tomorrow
I've fixed the problem:
  • The file config.plist was called confi.plist (missing the letter g)
  • That's why OpenCore could not read the configuration
Please try attached file.
Reactions: ExtremeXT
You miss some data’s like background or icon declared i your config
Read first lines of your screenshot
I'm here at the moment, maybe someone knows
    EFI.zip
In the EFI partition of the USB install disk there will be several OpenCore log files. Please upload the latest one.
@CaseySJ Good Morning and Thank you for your help
OpenCore logs MMIO virtualization information only after we boot the macOS kernel. If there are other OpenCore log files, please open them one by one and search for “MMIO”. If you find a log that has 2 or more matches, please send that log.
You need an MmioWhitelist, send the OpenCore log that was created with the DEBUG version of OpenCore and Target set to 67. Make sure DevirtualizeMmio is also set to True.
you must use a debug version of opencore
I see also some weird boot arg
like slide??
Post EFi or transform it in a debug one
like slide??
slide=xyz boot arg is automatically calculated and added by OpenCore.
@CaseySJ & @ExtremeXT I hope it is correct now this opencore version I used 0.86 debug...I recreated it as best as I could....sorry for the inconvenience
…I forgot to enter the 8 core cpu for info
It's good now, here are your MMIO values according to the log.
MMIO devirt 0xF0000000 (0x8000 pages, 0x800000000000100D)
MMIO devirt 0xFD000000 (0x1E00 pages, 0x800000000000100D)
MMIO devirt 0xFEE00000 (0x1 pages, 0x8000000000000001)
MMIO devirt 0xFEE01000 (0x11FF pages, 0x800000000000100D)
MMIO devirt 0x1080000000 (0x20200 pages, 0x800000000000100D)
MMIO (Memory Mapped Input/Output) spaces are split into ones that the BIOS uses, and the other ones are the ones that the OS uses. Unfortunately, macOS needs more MMIO spaces than what's available out of the box on Zen 4, so we will need to devirtualize the ones from the BIOS, which will make them usable to macOS. The next problem comes as we cannot give all of them to the OS since the BIOS also needs them for proper function (which is what is happening here, all of them are devirtualized as per the DevirtualizeMmio quirk, so the BIOS doesn't have any left), so we will need to create a whitelist. If an entry is whitelisted, then it will NOT be devirtualized and made available to macOS. Our goal is to only devirtualize the necessary ones and have as many whitelisted (non devirtualized) ones as possible. I hope you understand this, since my goal is for you to actually understand it, and not just to send it pre-made to you. Let me know if you have any questions and we will start doing the whitelist.
@ManuelB So, an MmioWhitelist entry in OpenCore has this structure:
  • Address - this is where the MMIO space address in decimal form will be inputted
  • Comment - this is optional but helpful to know which space is which
  • Enabled - denotes the status of the entry. Again, if Enabled is set to True then it will be whitelisted, hence will NOT be devirtualized, make sure to not get confused. For now set it to True.
In the Comment, you will paste the MMIO devirt line, for example:
In Address, you will paste the hex data (0xF0000000 in this example) in decimal form. For this you can use a hexadecimal to decimal calculator like this one: https://www.rapidtables.com/convert/number/hex-to-decimal.html
Repeat this for each of the 5 entries. After it's done, since all MMIO spaces are whitelisted, it means they will not get devirtualized, so it will be the same as DevirtualizeMmio being off. Now comes the trial and error part, figuring out which MMIO space has to NOT be whitelisted. I suggest starting with setting the last one to False. If you're unsure if you did it right, you can send a screenshot of you MmioWhitelist section.
Note: You can now switch back to OpenCore Release.
You might also need a custom version of SSDT-CPUR, send your DSDT (you can dump it with SSDTTime in Windows/Linux).
Reactions: ManuelB
@ExtremeXT it's interesting... i'll send you 2 pics didn't quite work out
or can I enter that via opencore
Add the comment as said in my previous message, and remove the first 2 entries which are from the Sample config.plist. (Hint: you can press CTRL/CMD-E then CTRL/CMD-M to automatically remove all Disabled values and comments)
Also, you did a typo, it's Address not Addres.
@ExtremeXT
I have now entered the data with opencore configurator that worked.. before with prober tree it only displayed a 0 as was seen in the previous post. I am very grateful to you for your support .... Oh yes, the typo came so since I have to translate everything Google Translate :-)
Okay, that means that the last MMIO space cannot be whitelisted (reserved for BIOS) since macOS needs it to boot. Try setting that one to True and the one above it to False.
