Yes i did..Did you change the Kernel > Patch core count according to the AMD Vanilla Github guide?
Yes i make installer with a virtual machin macos and the createvirtualmedia command.Okay have you tried booting with Monterey?
Here is a zip files with all the dumps:On top of this, I think we may need a BIOS DSDT dump of your system. Do you know how to do that? Grab a copy of Clover, put it onto a USB stick and press F4 at the Clover boot menu. It will save the files into the EFI/Clover/ACPI folder.
What is VESA mode?No and don't think they will (add support). However do not think it is necessary.
FYI I have successfully achieved booting on an AMD Ryzen APU before using VESA mode on my Atari VCS, and recently I made an updated version of my bootable EFI.
If you are willing to test, I've created an EFI recently for Ryzen 5800H/6800H IGPUs here which you can try.
VESA mode is when the GPU is only able to display in 2D mode but without any hardware acceleration. The name VESA stems from the PCs earliest days when the graphics cards makers back then were part of a larger working group that helped developed the graphics standards which included the monitor and motherboard makers. Standards such as EGA/VGA, the VGA socket link, resolution modes and flicker rate, the VESA mount point for LCDs (famously seen used with multiple monitors at stock exchanges and music concerts) ensured basic interoperability between video components on a PC. Some 300-odd firms had joined VESA which stands for Video Electronics Standards Association.What is VESA mode?
So do you have a solution to my problem ?On top of this, I think we may need a BIOS DSDT dump of your system. Do you know how to do that? Grab a copy of Clover, put it onto a USB stick and press F4 at the Clover boot menu. It will save the files into the EFI/Clover/ACPI folder.
Okay I've had a look at your DSDT. Try replacing the SSDT-CPUR.aml in your current EFI with this one. You'll need to unzip it first.So do you have a solution to my problem ?
Thank you for your answer but i'm sorry to tell you that didn't worked, here is the opencore debug logOkay I've had a look at your DSDT. Try replacing the SSDT-CPUR.aml in your current EFI with this one. You'll need to unzip it first.
Okay. Try with this new EFI.Thank you for your answer but i'm sorry to tell you that didn't worked, here is the opencore debug log
Hi thank your for yout folder but unfortunately, i can't boot, i reset system (didn't found the RESETNVRAM or Shutdown tool in options) and now opencore restart just after this message (i'm not stuck and my computer didn't shutdown, options where to boot are presented again):Okay. Try with this new EFI.
If it doesn't boot you must run the RESETNVRAM or Shutdown tool first before rebooting the EFI. That will clear the previous EFI cache.
You need to press the space bar at the Opencore options menu.Hi thank your for yout folder but unfortunately, i can't boot, i reset system (didn't found the RESETNVRAM or Shutdown tool in options) and now opencore restart just after this message (i'm not stuck and my computer didn't shutdown, options where to boot are presented again):
Thank you, i managed to clean NVRAM thanks to your help (in previous versions options where always visible) but now i get stuck on another message, first i have the first screen and then got stuck on the second photoYou need to press the space bar at the Opencore options menu.
Okay try to replace the SSDT-CPUR-ALT.aml in your EFI with this one. Remember to unzip it first before copying, then run ResetNVRAM before booting.Thank you, i managed to clean NVRAM thanks to your help (in previous versions options where always visible) but now i get stuck on another message, first i have the first screen and then got stuck on the second photo
I feel like it's endless
Thank you very much for your attempts to help
Thank you but not work! With this log and then rebootOkay try to replace the SSDT-CPUR-ALT.aml in your EFI with this one. Remember to unzip it first before copying, then run ResetNVRAM before booting.
I sent it few posts ago:@jonas0206 Can you send your DSDT?
Thank you for your folder but get Log exit error and then shutdown@jonas0206
Please try this EFI.
Try disabling SetupVirtualMap.I sent it few posts ago:
Now i’m stuck here « BuildActDeviceEntry exit »Try disabling SetupVirtualMap.
