    Votes: 12 75.0%
    Votes: 2 12.5%
    Votes: 2 12.5%
  • Total voters
    16
  • Poll closed .
Which version of OpenCore are you using with Big Sur?
Monterey requires OC 0.7.4 or newer. If you have an OpenCore EFI for Big Sur that is newer than version 0.7.4 then you should be able to use that EFI to boot the Monterey installer.
xenearz
Meh, I'm using version 7.1. Thanks a lot dude! Now I'm trying to update it...
xenearz
Fix here, update to 0.8.3
  • EFI 0.8.3.zip
Nextdoorboy
Hello guys, I think I found a fix to shutdown-restart problem when Erp enabled. This SSDT fixes my restart problem but renames XHC1 to AppleUSBXHCIPCI, so far I don't see any side effects, this is SSDT-SLEEP.aml from MIKIGL but I edited it for my XHC1Screen Shot 2022-08-13 at 16.19.55.png
  • SSDT-SLEEP.aml.zip
mr_1r0ny
Hi,
I have a problem - I updated to 0.8.3 and everything is working but I don't have correct entries for Platform/Processor/Serial Number etc.
I'm attaching screenshot from About Mac and screenshot of my Config.plist
Do you have any idea?
Hi,
If you haven't already done so you'll need to use SSDTPRGen to create the UUID and serials. Then under your PlatformInfo set the data there into the fields shown below not forgetting adding the Processor Type and also enabling ProvideCurrentCPUInfo:
mr_1r0ny
I did, and I see those entries in my Config.plist. Although they are not displayed in About Mac.
Try enabling RestrictEvents also and see if it helps.
mr_1r0ny
It is enabled
mr_1r0ny
mr_1r0ny
Alright. Have you added SMCAMDProcessor.kext and AMDRyzenCPUPowerManagement.kext?
yes sir, and in AMD Power Gadget I see all details correctly.
Okay. The only thing I can think of is this. Try setting your Processor Type to 0
then reboot.
mr_1r0ny
then reboot.
I tried with 0 and with the other one but no change at all. Unlucko I guess :p
errevi
Anybody upgrade to Ventura Beta 7 yet?
installed today beta version 22A5365d using open core 0.8.5 and latest kexts, so far so good
chiefsucker
Any Ventura public release success stories for this build, yet?
Is there something specific one needs to keep in mind, or does updating OpenCore, then the system basically do the job?
mr_1r0ny
I updated OC to 0.8.5 yesterday, as well as Kexts and successfully updated macOS to Ventura
