John's Asus X570 I Gaming EFI (Works on MOST Asus X570 & B550 Motherboards)
johnlietzke
Well-known member
It works!!! But the PC must be turned off and on. Restart doesn't work..Thanks, you are a genius (y)
Restart in the picker works fine on mine.
johnlietzke
Well-known member
Hi, has anyone been able to download the full installer (InstallAssistant.pkg) for Ventura Beta 3? The update still doesn't work for me.
Please if you have the link you can share it, thanks.
There is not full installer for beta 3. With beta releases Apple sometimes does not provide an installer, or waits until the public beta is released.
Pabo
johnlietzke
Well-known member
jarley91
Ok thanks for the information.
Additionally it happens that Apple TV and Netflix in Safari is shown in green color, I tried to search for a solution but nothing I find works.
johnlietzke
Well-known member
Maybe a GPU issue. What are you using?
jarley91
GPU: ASRock RX 6600 XT
<dict>
<key>@0,name</key>
<string>ATY,Henbury</string>
<key>@1,name</key>
<key>@2,name</key>
<key>@3,name</key>
<key>AAPL,slot-name</key>
<string>Internal@0,3,1/0,0/0,0/0,0</string>
<key>CFG,CFG_USE_AGDC</key>
<data>AA==</data>
<key>device-id</key>
<data>/3MAAA==</data>
<key>device_type</key>
<string>VGA compatible controller</string>
<key>hda-gfx</key>
<string>onboard-1</string>
<key>model</key>
<string>AMD Radeon RX 6600 XT</string>
</dict>
johnlietzke
Well-known member
<dict>
<key>@0,name</key>
<key>@1,name</key>
<key>@2,name</key>
<key>@3,name</key>
<data>AA==</data>
<key>hda-gfx</key>
<key>model</key>
</dict>
I have a 6800 XT and have no issues with discoloration.
Pabo
Installation of Beta 3 (22A5295i) upgrade is without a problem.
sac23
hi guys i have a 3950x with x570 cannot get monetary to boot or Ventura any help would be great thank u guys
johnlietzke
Well-known member
A list of all your hardware would be helpful.
sac23
ok sorry its
mother board x570 wifi aorus
1tb samsung ssd
cpu 3950x
16 gig ram
770 i think gpu
johnlietzke
Well-known member
ok sorry its
1tb samsung ssd
cpu 3950x
16 gig ram
770 i think gpu
This the EFI is for the Asus X570 & B550. Sorry can’t really help much with Aorus.
sac23
wanted to ask i have a efi that ws working for big sur can anyone update me to the newest oc if thats somthign that u guys can do here please
johnlietzke
Well-known member
sac23
ahh gotcha well thank u guys much appreciated
thisisgm
Is anyone else getting a black screen after wake up from sleep? It's happening to me ever since I upgraded to 12.4
jarley91
Hello, I can't resolve this error, I updated to OC 0.8.3 and the kexts to the latest version available, but I always have the same result with the installer and update of Ventura Beta 3.
