- Joined
- Jul 7, 2021
- Messages
- 304
Restart in the picker works fine on mine.It works!!! But the PC must be turned off and on. Restart doesn't work..Thanks, you are a genius
There is not full installer for beta 3. With beta releases Apple sometimes does not provide an installer, or waits until the public beta is released.Hi, has anyone been able to download the full installer (InstallAssistant.pkg) for Ventura Beta 3? The update still doesn't work for me.
Please if you have the link you can share it, thanks.
Ok, works even on reboot....Restart in the picker works fine on mine.
Ok thanks for the information.There is not full installer for beta 3. With beta releases Apple sometimes does not provide an installer, or waits until the public beta is released.
GPU: ASRock RX 6600 XTMaybe a GPU issue. What are you using?
I have a 6800 XT and have no issues with discoloration.GPU: ASRock RX 6600 XT
<dict>
<key>@0,name</key>
<string>ATY,Henbury</string>
<key>@1,name</key>
<key>@2,name</key>
<key>@3,name</key>
<key>AAPL,slot-name</key>
<string>Internal@0,3,1/0,0/0,0/0,0</string>
<key>CFG,CFG_USE_AGDC</key>
<data>AA==</data>
<key>device-id</key>
<data>/3MAAA==</data>
<key>device_type</key>
<string>VGA compatible controller</string>
<key>hda-gfx</key>
<string>onboard-1</string>
<key>model</key>
<string>AMD Radeon RX 6600 XT</string>
</dict>
hi guys i have a 3950x with x570 cannot get monetary to boot or Ventura any help would be great thank u guys
ok sorry its
mother board x570 wifi aorus
1tb samsung ssd
cpu 3950x
16 gig ram
770 i think gpu
wanted to ask i have a efi that ws working for big sur can anyone update me to the newest oc if thats somthign that u guys can do here please
