Could macos be installed in this Laptop? I didn't see any preinstalled EFI configuration file for this computer?
Have any idea?
Thank you
Have any idea?
Thank you
I think it can be done given that the RX6600M is working now with the Lenovo Legion 5 who also has this CPU/GPU (5800H & 6600M). This would be the EFI you could use > https://forum.amd-osx.com/index.php...monterey-kernel-panic.2725/page-20#post-19937Could macos be installed in this Laptop? I didn't see any preinstalled EFI configuration file for this computer?
Have any idea?
Thank you
Would I borrow the EFI for Lenovo Legion 5 to automatically install it on HP Omen without any change?I think it can be done given that the RX6600M is working now with the Lenovo Legion 5 who also has this CPU/GPU (5800H & 6600M). This would be the EFI you could use > https://forum.amd-osx.com/index.php...monterey-kernel-panic.2725/page-20#post-19937
Natively, no, because the GPU doesn't have a Mux switch. Maybe via Proxmox you may be able to access the GPU, but that is a risk.Could macos be installed in this Laptop? I didn't see any preinstalled EFI configuration file for this computer?
Have any idea?
Thank you
Not the same. The Omen doesnt have a MUX unlike the Legion 5 and the Asus G14. These 2 models are the current and only 6600 laptops that allow to disable the IGPU at a bios level.I think it can be done given that the RX6600M is working now with the Lenovo Legion 5 who also has this CPU/GPU (5800H & 6600M). This would be the EFI you could use > https://forum.amd-osx.com/index.php...monterey-kernel-panic.2725/page-20#post-19937
Wouldn’t that disable the 6600m, when there is no Mux, the only way the gpu connects to the Motherboard is via the igpu. Hence why the Legion 5 and the Asus G14 are unique. Now I am curious?You could try using the WhateverGreen.kext boot argument to disable the IGPU.
The disable-gpu entry might looks something like this:
- -wegnoigpu to disable internal GPU or
- add disable-gpu property under IGPU Device Path entry
- PciRoot(0x0)/Pci(0x1,0x0)/Pci(0x0,0x0) > disable-gpu > data > 01000000
