Is HP OMEN - 16.1" Gaming Laptop hackintoshable?
Could macos be installed in this Laptop? I didn't see any preinstalled EFI configuration file for this computer?
Have any idea?
Thank you
I think it can be done given that the RX6600M is working now with the Lenovo Legion 5 who also has this CPU/GPU (5800H & 6600M). This would be the EFI you could use > https://forum.amd-osx.com/index.php...monterey-kernel-panic.2725/page-20#post-19937
You need to have a look at this post.
Jo-Toku
Have any idea?
Thank you
Natively, no, because the GPU doesn't have a Mux switch. Maybe via Proxmox you may be able to access the GPU, but that is a risk.
Maybe you can get it working without graphics acceleration
Edit: I could not find if the 2022 model of the Omen 16.1 which includes the updated RX6650. have a MUX. in 2022 many manufactures started including MUX'es. see if you can dig any info on this. if not, I'll stick to the Asus G14, unfortunately the screen is small
Jo-Toku
Not the same. The Omen doesnt have a MUX unlike the Legion 5 and the Asus G14. These 2 models are the current and only 6600 laptops that allow to disable the IGPU at a bios level.
Having said that, maybe that can be solved with Proxmox, but is just a guess
You could try using the WhateverGreen.kext boot argument to disable the IGPU.
  • -wegnoigpu to disable internal GPU or
  • add disable-gpu property under IGPU Device Path entry
The disable-gpu entry might looks something like this:
  • PciRoot(0x0)/Pci(0x1,0x0)/Pci(0x0,0x0) > disable-gpu > data > 01000000
Jo-Toku
Wouldn’t that disable the 6600m, when there is no Mux, the only way the gpu connects to the Motherboard is via the igpu. Hence why the Legion 5 and the Asus G14 are unique. Now I am curious?:unsure:
You are probably correct but the only way to know for sure is to try using the boot argument and see what happens.
