zxc2689963
135
92
28
Brand: Lenovo
Model: Legion 5 6th Gen
CPU: AMD Ryzen 7 5800h
Ram: x2 8GB 3200mhz ddr4
Display: 15.6 1080p 165HZ
Updated October 5, 2023
Problems solved:
Unresolved issues:
Failure to wake from sleep
Solution
Panic from Monterey 12.6
Okay @zxc2689963 & @Jo-Toku,
I have one more thing for you to try. Please test this new SSDT-CPUR-5800H-1.aml file.
Disable your SSDT-CPUR (keep it aside) and use this one instead and let me know if it works.
It may be able to run macOS without using cpus=1.
Thanks for your help, but failed again, unable to get rid of cpus=1, which was annoying
Reactions: Middleman
I still cannot get past installing 11.6.7, it hangs in different spots around ionvme, can anyone confirm they are using a Realtek wireless m.2? I believe that is the culprit. That or the fact I’m using 2 identical ssds maybe. (I am trying to install with efi started from on post #98
I am not. I swapped it to a fenvi m.2. The drive is a Western Digital Black SN750
Yeah I ordered an Intel ax210ngw wireless card… will be here Monday so hopefully that will solve the issue. If not I may switch to SN 750 SSDs… these xpg gammix blades were working on a couple of my other ryzentoshes so I assumed they should work with this, but since the legion is finicky it might be them causing the hang.
Reactions: OG Nerd
It was impossible to install anything on the drives that the Legion came with. Mine came with 2 TB and none of the 2 drives worked
Note: my fenvi wifi dont work. The Bl does. but it works on other oses, weird
Reactions: OG Nerd
BigSur does not start successfully every time, there will be a probability of getting stuck in (IONVme or apfs_module), and it needs to be forced to restart several times.
Yes sure. You should have told me earlier.
There was a reason why I made that - because I discovered that the SSDT-CPUR you are all currently using is mainly for the desktop Ryzen series - not laptop by looking through the DSDT dump - that’s why it struggles to boot in Big Sur. I think you should try using the new one for now until we find a way to sort out the CPUs=1 issue. Perhaps TSCAdjustReset may work with it.
Reactions: OG Nerd
Guys,
Would it not be too troubling for you if I could ask you for an IOReg dump of your current working system on the Legion 5 with Big Sur?
I am just a bit curious and want to know more about the system.
Also I want to check - if you type in: kextstat | grep -E "AppleSMBusController|AppleSMBusPCI" what does it show for you in Terminal?
Guys,
I am on Monterey unfortunately
Guys,
I have an IOReg file that saves BigSur
Reactions: OG Nerd
@zxc2689963, I noticed on your config you filed the the device property of the RX6600m. What does this do?
Was this to avoid the white noise when getting to the installer screen?
Reason I ask:
In have 3 laptops with 2X with RX580's and 1X with Vega 56. and none allow me to enter the installer page after Mojave. From Catalina to Monterey I get white noise instead of the installer page. I dont have that issue with High Sierra and Mojave. I noticed that the GPU device property differs from your config. Now, have you ever witnessed the white noise and if so, how did you solve it?
Reactions: OG Nerd
Reason I ask:
@Jo-Toku
Actually that should be quite easy to fix. I have a RX550 set up for my B550 here >
In addition to the device-id I use the setting no-gfx-spoof set to 01000000 using Type: Data. This allows any AMD card with similar specs to be used. It also needs the boot-arg npci=0x2000 agdpmod=ignore (this is for RX580 cards). This could work for Vega64 too.
On laptops you may also need the PEGP to GFX0 ACPI patch.
  • Love
Reactions: Jo-Toku
@Jo-Toku
Nice, can you confirm that you have witnessed the white noise on the installers starting with 10.15-12 before and this solved it? 🔥
I haven't seen any white noise, but I can also tell you I managed to install both Mojave and Catalina on the Atari VCS which uses an AMD APU with a Vega64 chip.
I made a guide for it here > https://www.tonymacx86.com/threads/guide-atari-vcs-2020-console.309903/
I think you should have a look at it because it is a more compatible setup for AMD based laptops, particularly if you want to get the graphics working.
I haven't updated it yet with the new no-gfx-spoof method as that was a recent addition from Opencore. But I think it should work.
