John's Asus X570 I Gaming EFI (Works on MOST Asus X570 & B550 Motherboards)
johnlietzke
Well-known member
I will make USB Ventura and try installation from it
I would suggest trying the 0.8.1 EFI for the install. It is the one I used to install Ventura, the only change I made was the removing the PlatformInfo. You should probably change your Core Count to be on the safe side.
Pabo
Core Count we have the same
johnlietzke
Well-known member
Someone on Discord AMD OS X reported that without an internet connection the installer goes into a boot loop. They do not have a compatible WiFi Apple card. In addition, it is unclear if Lucy Realtek is working with Ventura.
I have no way to test, my ITX X570 has a 1GB port and SmallTree is fundamentally broken.
Pabo
OK, I did a clean installation of USB Ventura beta + your OC 0.8.2 and the installation is OK and so far everything works .... Thanks for your help. I will test and report. Lucy Realtek works normally.
Edit: I left your OC 0.8.2 as it is, I haven't changed anything yet
johnlietzke
Well-known member
It must be something with the upgrade. Discord has a lot of posts talking about problems upgrading from Monterey for many on AMD. Shaneee provided the patch. I will update the EFI post too include new install.
I did have one crash when transferring adding about 100 photo files to an Album album in Photos.
ccphuc
AMD Ryzen 3600 + ASUS X570 Pro can't boot why ?
johnlietzke
Well-known member
ccphuc
johnlietzke
Well-known member
Did you do a new install with the volume formatted as APFS and reset the NVRAM?
Make sure to remove NVRAM -> Add-> 7C436110-AB2A-4BBB-A880-FE41995C9F82 -> boot-args -> agdpmod=ignore from the boot arguments.
ccphuc
My EFI
Opencore 0.8.2 + all new kext Lilu.kext 1.6.1, AppleALC.kext 1.7.3, WhateverGreen.kext 1.6.0 + boot args -v npci=0x2000 alcid=7 watchdog=0 agdpmod=pikera
  • EFI OC 0.8.2 ASUS X570 Pro CSM.zip
johnlietzke
Well-known member
Glad you got it work.
ccphuc
iamprabhuantony
My EFI
What App is this? Could you please Share the Link... Thanks
johnlietzke
Well-known member
ccphuc
freeubi
Thanks for your work.
I tried to do an clean install with 0.8.1 and 0.8.2 beta, but it didn't worked.
What worked me is a clean 12.4 install [with 0.8.1], then update it via the updater. The downloaded installer dont worked for me for some reason.
I had done only one change to you config, remove the ethernet kexts.
I will test more later, but all of the main things are working.
I have 3900x, with a Gigabyte X570 AORUS ULTRA and a radeon x560.
johnlietzke
Well-known member
There seems to be a lot of variation for what works installing Ventura and what does not. I could never get the upgrade to work. Hopefully the next OpenCore release irons things out for installing and upgrading.
johnlietzke
Well-known member
OpenCore 0.8.2 EFI Pre Release - June 28th, 2022 11:20 AM (PST)
Confirmed: MacOS Ventura (Beta 1 & 2) and Monterey.
Updating Nuances:
  • This EFI only works for doing a new install of Venture. Upgrading from Monterey fails to properly install.
  • Updating Ventura from Beta 1 to Beta 2 works properly.
Link - MacOS Ventura 13.0 Beta 1 Installer
The following Kext have also been update to pre release version:
Kext added for other Asus X570 & B550 motherboards: Not able to test on Asus X570 I Gaming.
Make your new volume/partition is formatted to APFS. In the past JHFS+ was use, but now the installer fails if the drive was formatted to JHFS+ prior to install.
Required BIOS and EFI Setting:
  1. BIOS Settings
  2. EFI Settings
  3. NVRAM Reset
  • OpenCore 0.8.2 Pre Release Updated.zip
Pabo
Updating Nuances:
  1. BIOS Settings
  2. EFI Settings
  3. NVRAM Reset
Thanks for your work. I installed Beta2 installation. Unfortunately, the installation will stop on this problem. No Username and Password work... writes about this problem on Discord ...
EDIT : Installation Beta 1 is OK- After the update to beta2 is OK
johnlietzke
Well-known member
There seems to be a lot of different problems that are arising with Hackintosh installation of Ventura. The problems are all over the place, like asking for a password.
When updating to Beta 2 after each restart I was directed to the login screen to enter my password. I had to do it 3 times to complete the install. So maybe you just need to enter you username and password to upgrade. Mine took me to the normal login screen.
