New update mac os 12.4 monterey
Aledky91
A new update for mac os has been released. This time it's 12.4. Has anyone updated yet? Is there some kind of problem?
No issues ;)
Big Sur has been updated to 11.6.6.
sos86
Moozuki
I'll find out in a couple of minutes.
Love your avatar btw.
No issues here:
sos86
Add the boot arg e1000=0 and use AppleIGB.kext
Thanks Shanee. Oddly enough a simple reboot seems to have fixed things (+running disk first aid perhaps). I'm using your AppleI2xx kext from late last year, by the way.
AMDPUSH
AMDPUSH
If someone need it, just put your platform info and be sure to log with the MacPro Profil on your apple account before changing IMacpro to Macpro if you needed. hot plug with Satelite Octo TB3 Universal Audio. Nuendo 12 ok. need to disable SIP for some plugins, or allow install app from developper from anywhere in terminal instructions. For the waves there is AMDFriend solution.
  • EFI OC 080 12.4 Aorus Master.zip
Bansaku
lgk619
Update to 12.4, my usb does not work and it does not recognize any hard drive that I have installed, I have an AMD RYZEN 5800X + X570 AORUS MASTER AND 5700XT
jberdan
Vous avez la même carte mère que moi et je vois que vous utilisez AppleGB.kext ; Des problèmes avec 12.4 comme des problèmes de vitesse ou de sommeil ? ?
Verser des informations,
Ne pas mettre à jour votre BIOS/EFI à la version f36 ou f37a ou f37c car retour en arrière impossible. De plus, ils sont 'boggés'. et votre hackintosh ne démarrera plus, (sauf Windows) Gigabyte averti mais ... aucune réponse! Certains forums en ont fait part mais ... trop tard pour moi! J'attends donc une version stable ...
Anyone wondering what the message above is about, here is the translation.
Do not update your BIOS/EFI to version f36 or f37a or f37c because rollback is not possible. Moreover, they are 'bogged'. and your hackintosh won't start anymore, (except Windows) Gigabyte warned but... no response! Some forums have reported it but ... too late for me! I'm waiting for a stable version...
uzmi
All good, no problems but... using bios 7C37v18
Clean installation
DarkSilentSC
For me on the I211- It works only for like few minutes and it disconnects itself.
Bansaku
Say what now?! I am on f36 and all is well.
