Fix shutdown issue
Answers to your questions:
  1. Which of the Ports are associated with the 4 x Physical USB2 ports on the rear I/O plate?
    I've put the USB 2.0 stick in all the 4 physical USB2 ports and in all 4 scenarios it will be visible for port 16 (the one i've set as internal since it seems an USB2.0 hub)
  1. The ITE hub how is that identified, i.e which physical port are you connecting a USB Device to when it is discovered?
    ITE Device (8595) is visible from the start, even when I don't connect any USB device. I have the feeling it is the RGB controller which I don't use at all.
    As a test I disabled it in a testing USBMap.kext (without further configuration) and all the usb ports working just fine (tested after a reboot with this test kext ofcourse), so I think I can disable it.
Then change the Port 16 to USB2 (0), it is not an internal port, but rather a USB2 hub that serves 4 x physical ports.
Yes, you can probably disable the ITE device.
Do I need to change both USB 2.0 hub ports (port 6 and port 16) to port type 0 (so also the one which has a bluetooth device connected according to the mapping tool) ?
No idea, as it is not really clear which port is being identified in the USBMap screenshot.
I have attached screenshots of your Motherboard layout and the Rear I/O plate, with each USB port or header given a clear identifier. Can you use these identifiers and annotate which port is being identified when you insert a USB Device.
Also can us use a USB2 pen drive, rather than the read/write flash drive you are currently using. Just humour me.
Screenshot 2022-02-11 at 19.35.20.png Motherboard layout with Headers identified
Screenshot 2022-02-11 at 19.35.43.png Rear I/O plate with ports identified
Blank screenshots for you to use when annotating the ports as they are identified. It is very easy to add text to these images using Preview app.
Here an overview of the ports
New created mapping:
The Devices I used to identify the ports are:
  • USB 3.0 USB stick (name = Ultra)
  • USB 2.0 USB stick (name = Disk)
  • USB-C cable connected Samsung Portable SSD T5 (name = Portable SSD T5)
  • USB-C cable connected phone (name = Mi 9T Pro)
Port 6 needs to be changed to 255 (internal), as the two front case USB2 ports and Bluetooth module are served by the two internal header ports.
Other than that one change the rest looks really good(y)
Thanks, I just changed it. Unfortunately, I still facing a restart after shutting down the system.
This is the port configuration I currently have:
After adding the kext to my OC folder and config.plist file and doing a reboot, I see this when I open Hackintool and clear+refresh the list:
At this stage I only have connected an usb mouse and usb keyboard to one of the USB2 hubs.
From what I found in the readme file at: https://github.com/corpnewt/USBMap is this:
- Can map USB 2 HUBs (requires the HUB's parent port uses type 255)
Does this mean I need to set both hubs to port type 255? Instead of one the current situation where i've set 0 for one of the usb2 hubs
Another strange thing I see is that the names of the ports are changed from prtxx to HSxx and SSxx. Is this normal using this mapping tool?
PS. I also uploaded the kext file.
No, do not set both as Internal (255). Only HS06 on the XHC1 controller needs to be set as internal. The other should be set as type USB2 (0).
Yes the port name changes are normal.
That USB configuration looks good to me. I would stick with it and not change anything.
What that means is you have a companion issue that is causing the shutdown problem, which is as yet unknown.
Can you post a copy of your IOReg, so I can see what is being activated in your system. Use the copy of IORegistryExplorer attached below. Do not use a newer version as they tend to corrupt the IOReg file.
Installation
1, Open Downloads/IORegistryExplorer-SLRID_v10.6.3
2. Drag IORegistryExplorer to Applications Folder
How to Make a Copy of IOReg (Note 1)
1. IORegistryExplorer/File/Save a Copy As…. (no extension required)
2. Open file to verify (Note 2)
3. Attach to post (Note 3)
Notes
1. An IOReg.txt is not useful. It is not a "Copy of IOReg." Do not attach .txt files.
2. IOReg must open the file. If TextEdit opens, See Note 1.
2. If the web site will not accept the file, compress it (Finder/Compress ... )
In the meanwhile (before you answered) I already tried something else.
I found another XHC.aml version for an almost similar motherboard (https://forum.amd-osx.com/index.php...nterey-beta-opencore-0-7-4-efi.1344/post-6972) which has different names for all the 3 XHC controllers. I thought maybe that could help but unfortunately it had no effect on the shutdown issue.
The current situation on my machine (I recreated the mapping to ensure it is still correct). I hope it does not matter, otherwise I will revert back to the situation in my previous post.
This is the current situation:
Outcome is the same, only difference is that none of the controllers have the same name.
PS. I attached the export you requested (filename: MacPro.zip).
I also added the current USBMap and XHC.aml in case it is relevant.
Ah before I forget (maybe it is relevant), there is a known hardware issue with the motherboard I have (Gigabyte Aorus Ultra x570) that the internal WIFI/bluetooth disappears and is not accessible when you enable ERP in the BIOS (also in Windows and other operating systems).
More info about this:
www.reddit.com/r/gigabyte/comments/cz5n2s/x570_aorus_ultra_and_x570_aorus_pro_wifi_enabling/
Because of this issue and the fact that the Intel AX200 WIFI chip was very unstable with itlwm.kext, I decided to buy a separate wifi/bluetooth module that works out of the box in MacOS (Fenvi BCM94360NG). This one is connected using a PCI adapter. Probably you will see this device in the export I uploaded in my previous post.
As far as the USB port mapping is concerned it all looks good to me. Everything is matching up and shown in the IOReg you provided, in line with the settings above. I think it is the finished article.
WiFi/BT cards:
Have you physically removed the Intel WiFi/BT card and replaced it with the Broadcom card? As the Broadcom WiFi/BT card is the only one that shows in your IOReg
Screenshot 2022-02-13 at 20.46.17.png Broadcom WiFi controller
Screenshot 2022-02-13 at 20.46.51.png Broadcom BT controller/USB connection
Can you post a copy of your System DSDT.aml so I can check something regarding your EC controller and USB power settings.
You can use Hackintool > Utilities > Dump ACPI tool to download (Dump) your ACPI tables to a folder on your Desktop. The DSDT will be among the ACPI tables. Just compress the folder you create (as the place to save the tables) when going through the Hackintool wizard.
No, the internal Intel WIFI/BT card is still in place. It is just not accessible at all when ERP is turned on in BIOS (the same is true in Windows).
I turned on ERP because otherwise my keyboard backlight will flicker all the time when the PC is shutdown.
I attached the ACPI dump.
Can you remove the Intel Card?
If it is disabled and you are not using it, all it will do is cause conflicts in macOS.
I will look at the ACPI dump tomorrow.
I took me a few hours but I succeeded. The Intel WIFI/bluetooth card is removed.
Evidence ;):
After:
The bad news is, it didn't solve the shutdown issue.
Reactions: Edhawk
I used your DSDT.aml and corpnewt's SSDTTime python script to create this SSDT-EC.aml for your system.
It should be added to your /OC/ACPI folder and a corresponding entry added to your config.plist.
If I recall correctly the list of SSDT's you provided previously didn't include an SSDT-EC.aml.
@Edhawk thanks again for all the time you take to help me. Really appreciate it.
I tried the SSDT-EC.aml you provided but unfortunately it does not fix the issue. The machine still restarts after a shutdown.
I tried two configurations:
Configuration 1:
Config file:
Corresponding files:
Configuration 2:
Config file:
The SSDT-XHC.aml is for both configurations the same since I am sure this one is correct. The other aml files I am not sure of so therefore I've tested both scenarios.
The aml files in the first configuration I got from AudioGod: https://forum.amd-osx.com/index.php...ig-sur-monterey-beta-opencore-0-7-4-efi.1344/
The aml file in the second configuration (SSDT-EC-USBX-DESKTOP.aml) I found in the OpenCore documentation: https://dortania.github.io/Getting-Started-With-ACPI/ssdt-platform.html
The result is the same for both configurations.
Any other idea or suggestion I could try myself?
PS. I don't want to disable ERP in bios because like I said my keyboard backlight will flicker in that case when my PC is shutdown.
For Windows it all works fine so I would assume there must be a solution to fix this for MacOS.
I'm not sure what else to suggest, if I am honest.
Never mind. I will continue search for a solution.
Thanks for all your help. At least I now understand how to properly map USB ports myself.
