Fix shutdown issue
Never mind. I will continue search for a solution.
Thanks for all your help. At least I now understand how to properly map USB ports myself.
Hi, can you solve the problem? I have x570 master and same problem happens to me, sleep worked a while on bigsur (after adding second Broadcom wifi through nvme slot with m2 to name adapter broke the sleep) but shutdown always problem with erp enabled or disabled
hi, i f you have correctly map your USB, with the tools you can find in the resources on this forum, i think you may be have some powered USB devices connected to your HAck. If you change the port, you can find witch of the usb shuting down correctly and plug your external USB device on it. Try to connect an external SSD and see if it's shuting down correctly or not; looking at the light on it.
https://forum.amd-osx.com/index.php?resources/usb-mapping-script.8/ Be very careful of all the devices already connected internally the bluetooth or the water cooling for example
