Before updating to Monterey 12.3 Beta (21E5196i)
11
1,412
212
33
Scotland
amd-osx.com
Ryzen 5 5600X
Apple have once again changed something that affects booting macOS on non Apple Hardware. However there is a simple fix. AppleMCEReporterDisabler.kext is required again to boot as something changed with the SMC. So for the time being include this kext in your EFI/Config to boot if you plan on installing the beta. Credit to Pavo for finding this information.
Thanks,
GPU performance has taken a big hit. Yes.
Just got the notice for 12.3 Beta 3 available. Anyone pull the trigger yet??
@Shaneee to clarify on Bluetooth, are you saying you don't use Bluetooth on your main rig, or that It works OTB with your config (not using the BlueToolFixup and IntelBluetoothFirmware kexts) ? I did find that with the IntelBluetoothFirmware and BlueToolFixup kexts enabled, my system was kind of buggy
Right now beta 3 is totally broken. Freezes and crashes are common.
@Seyven Good to know, I will hold off for now
Made same experience with Monterey 12.3 Beta 3. Crashing and freezing all the time went back to official 12.2.1
BT works OTB with the adapter I use.
Hi, there,
I update Monterey 12.3 from 12.2.x,
but GPU performance is too slow..(RX 6900XT)
Someone resolve this problem?
Shaneee - _mtrr_update_action fix PAT - 10.13/10.14/10.15/11.0/12.0 patch is True.
I have no idea.
Please give me advise!
I'm on beta 5, nothing has changed at all. Pretty bad performance.
Reactions: Mymlan
bad graphics performance for me too, RX 5700 XT.
Reading other forums, there are problems with the Radeons even with Intel processors
Reactions: Seyven and Mymlan
Reading experiences, I'm gonna hold off. This sounds like a 12.3.1 will probably be out soon.
before and after 12.3
It seems that changing Device Properties in OC will fix it.
Basically, the RX 5700 XT become W5700X and this would solve the problems
Someone with RX 5700 XT upgraded to 12.3 might do some testing, I just downgraded to 12.2.1
Reactions: Aluveitie
I guess no fixes for RX5500XT
grazie baronerosso, tested with a powercolor red dragon rx 5700 xt but can not boot, had to go back to 'unfairgva'
Perhaps power supply trick maybe can fix bluetooth issue? (Turn off PC, unplug power or switch off power supply for 30 sec+, and power back on)
Can I add that MCEReporterDisabler kext for 12.2.1 prior to it without breaking boot?
Did you edit this to fit your Device Path?
PciRoot (0x0) / Pci (0x3,0x1) / Pci (0x0,0x0) / Pci (0x0,0x0) / Pci (0x0,0x0)
no need, the device path is exactly the same, double checked and got it working cleaning a typo, my bad
thanks again!
This worked for me! thank you!
Reactions: baronerosso
I have installed 12.3 on an external hard drive and I confirm that the Device Properties hack works, at least on my hackintosh.
In this thread in the Tonymacx86 forum, there are hacks for many other NAVIs
