Pabo
Hey all.... I updated AG's 0.7.4 EFI with 0.7.5 - Removed the platform info and set ReSizable Bar to work with OSX and WIN.
AG - I hope you don't mind, I will delete if not alowed.
Everything works ok? No problem with Bluetooth? (I have a BCM94360NG) I had to go back to Big Sur, Blutetooth OpenCore 0.7.4 made me problem when waking up from sleep. Thx
DaddyB
I have not seen anything yet, sleep works ok. I don’t use Bluetooth all that much though.
Pabo
Did you exchange the new kext? I was watching and you have old ones there .... Whatever, Lilu, AppleALC are newer ...
DaddyB
I did not - AG's 0.7.4 with kexts was working perfect for me so I left them
I have WEG disabled for the BigNavi
I'll try the new Lilu and AppleALC and report back
DaddyB
Ok, so added updated WEG, Lilu, and AppleALC - still have WEG disabled in config.
Sleep is in fact NOT WORKING -
I was trying to put to sleep manually - Starts to sleep and immediately does a soft reboot (POST indicator lights on motherboard, but not a full reboot) and wakes from sleep. Disabling Bluetooth and Wifi in OS X has no effect.
Wake for network access is unchecked
Disabled Onboard audio Wifi, bluetooth, and 1g Eth from BIOS - still having the same problems. (Using Fenvi PCIe BCM Wifi+BT, and Presonus USB Audio)
salmantechnical123
Hey Audio God ! You Did A Wonderful Work ! Iam Actually New To This ! I tried Creating One For ASUS ROG B550-F GAMING WIFI ! I Stuck With Few Issues ! If You Don't Mind ! Can You Help Me To Fix Those ?
johnlietzke
Well-known member
MacOS Monterey 12.1 Beta 2 works without any changes to the EFI or BIOS!
johnlietzke
Well-known member
AudioGod had a catastrophic incident that destroyed most of his hardware and a significant number of electronics in his home. He is currently on hiatus while trying to get his system back up and running.
Pabo
Little information-I sold the ROG Crosshair VIII Dark Hero motherboard and bought the novelty ROG STRIX X570-E GAMING WIFI II. I used EFI without change from @AudioGod (thanks) and it works fantastically so far! DARK HERO also worked OK but sometimes had a problem with USB. If you want some info I will be happy to answer
johnlietzke
Well-known member
Just want to let everyone know that 12.1 beta 3 works.
johnlietzke
Well-known member
LaytonX
I have the Dark Hero board with the 2.5G and Intel 1G ethernet ports. The 1G port doesn't work at all (did in macOS Big Sur) and the 2.5G port is finicky. Works fine most of the time, but sometimes when uploading the connection drops completely requiring a reboot to get back network access. Anyone else experiencing this? Thinking of reverting back to Big Sur.
johnlietzke
Well-known member
The 1GB Ethernet port requires the SmallTree Kext which stopped working again with Monterey.
marinekev88
Any issues so far? I have the prompt to update to Beta 3 and I have been holding off
johnlietzke
Well-known member
Jatilq
Everything important seems to be working thanks to this thread, but I can't get Hardware Acceleration with my Asus Strix 6900XT. I guess I should be thankful, the last few times I tried to install opencore, it wouldn't detect the card at all.
The card should work OOB. Try disabling Whatevergreen.kext in the config.
If its the Liquid Cooled Strix it has the unsupported Navi 21 XTXH variant. You can try spoofing the device ID. If that does not work you would need to flash the card with a Navi 21 XTX BIOS.
