Upgrade path to success
savage001
192
56
28
44
Adelaide
Ryzen 9 5900X
So fingers crossed I’ll hopefully soon be getting my hands on a Ryzen 7 5800X and a Gigabyte Aorus Radeon RX 6800 XT Master 16GB GPU. Currently have a rx580 and a R5 3600.
What would I need to do before powering down to replace parts to ensure successful boot?
Just change the core count patch? To what?
Boot args for GPU? Which one?
Is the above a good & worth while upgrade?
You don’t need to do anything other then the core count and add agdpmod=ignore to your boot arguments or even better don’t add a boot argument and just disable WEG all together (Big Navi definitely works better without WhateverGreen then with it IMO)
Thanks. But looks like I’ll need to pull the budget in and maybe get a 6700 xt.
Still gotta be a good upgrade from the rx580?
Would the same apply for the 6700 as for the 6800?
I don’t know much about this brand, any good?
PowerColor Radeon RX 6700 XT Red Devil OC 12GB RDNA 2
6700 has no support on MacOS, 6600 does though using 12.1 beta
Oh damn. I had hoped with the 6600 support 6700 would be supported also.
So something like this?
PowerColor Radeon RX 6600 XT Red Devil OC 8GB RDNA 2
Being the bottom end of the 6000 series wouldn’t see much improvement over the rx580 would it?
For gaming and general usage.
Its trades blows with a 5700 XT.
Reactions: DEXTER-AMD
Thanks for that. So at 1440p it shouldn’t be too bad and still a definite upgrade from a RX580 8G.
I’ll see how the budget holds up. GPU prices are crazy high here in Aus. 2k minimum for a good card.
Although I just found this for $1699
PowerColor Radeon RX 6800 XT Red Devil OC 16GB RDNA 2
What are your thoughts on the cpu upgrade? Worth the upgrade or do I try bounce up to a R9 5900X ?
Bios update to support 5XXX series?
Reactions: Cyberdevs
I’m always on the latest bios and at present it’s a beta bios. Bios support for 5000 series was added a while ago.
Ok I think I’ve decided on the below.
Is powercolor a good brand?
850w should be fine yeah? I currently have an 850w but it’s getting a bit long in the tooth
Change of plans. About to pull the pin on this.
From a Ryzen 5 3600 and a sapphire RX 580 8gb.
Can anyone see anything wrong?
What about a 5700g will it work?
@savage001 Don't get the APU, it'll cause audio issues even with the iGPU disabled.
Yeah I didn’t. I went with a R9 5900X, Powercolor RX6800XT Red Devil OC (sale ends in less than 2 hours) and the Phanteks Revolt Pro PSU as well as the lian li GPU anti sag bracket.
Hopefully I did well.
I remove argument and WEG from my kext folder ? because i have a black screen even i use yhe same EFI 074 frome my 11.6.1 when i upgraded to 12.0.1
how to disable WEG ?
Well my parts have arrived, now the fun begins.
Ok so disabling weg brings me to a black screen after entering my password and so does adding the boot arg adgpmod=ignore.
I ended up getting a RX6800XT.
Core count patch is fine just no display.
I’m using DisplayPort but can change to hdmi if it’s better.
Do I need to set bios to gen 3 or gen 4?
It’s on Auto now.
I’ve tried gen 3 and 4 with and without weg with and without adgpmod=disable & pikera.
Could it be a ssdt? SSDT-SBRG in particular?
Card device id is 73bf.
