You should find it under the same section where ERP is and disable ERP if its enabled while you are at it.Restarting and no Shut down. I went to the Bios F34 and no power option for PCI
Thank youits a little script that's inside the Utilities folder in OpenCore that will tell you if your Config,plist is in line with the revision you are trying to use it with.
Its a much better idea to use the Config.plist I supply with new EFIs and put your info back into it otherwise you may miss vital changes I might make and it will save you problems as the config will always be inline with the EFI.
Have you tried fixing the problem via a SSDT bud?Ok the EFI you sent me back is OKKK!!!
And what about the shut down problem . I sent you a picture of my Bios
