AMD AGESA ComboAM4v2 1.2.0.2 Shutdown/Restart
Restarting and no Shut down. I went to the Bios F34 and no power option for PCI
You should find it under the same section where ERP is and disable ERP if its enabled while you are at it.
Im booted now directly off the Thread 0.7.3 EFI and OpenCanopy is fine and it booted just fine too. Something weird is going on with your setup over there bud.
Your 073 EFI adapted to me
I see what the problem is :)
You can't carry across the Config.plist from one revision to the other without using OC Validate first.
as in this instance,
This
In 0.7.3 is now like this
You were also missing the flavours section in tools.
Here you go, Try now. ;)
Reactions: AMDPUSH
I will try right now ! Thanks
What is OC Validate ?
its a little script that's inside the Utilities folder in OpenCore that will tell you if your Config,plist is in line with the revision you are trying to use it with.
Its a much better idea to use the Config.plist I supply with new EFIs and put your info back into it otherwise you may miss vital changes I might make and it will save you problems as the config will always be inline with the EFI.
Reactions: AMDPUSH
Thank you
Ok the EFI you sent me back is OKKK!!!
And what about the shut down problem . I sent you a picture of my Bios
Reactions: AudioGod
Have you tried fixing the problem via a SSDT bud?
Hi, i don't really understand the process on the dortania page for the shutdown/restart : I have my DSDT, but i don't how to find the -PWR in the DSDT, (don't see any search windows ) After that i'am not sure if it create a SSDT i have to add it to my ACPI folder or modify the -PLUG one, and if i have to add the patch in my config.plist and at which folder, line, where
