Hello sir, Thank you for your reply I donāt know exactly how to do it is there any tutorial or could you edit it for me and pack it as zip and send it if possible, Thank YouYou've not added the AMD Kernel Patches, https://github.com/AMD-OSX/AMD_Vanilla
no luck sir same problem Pendrive is not showingReplace the config with this one.
If you are using my EFI I have the recovery drive that Iām guessing your trying to use hidden as standard.Its not working sir
Ahhh ok thatās explains it.High Sierra
Try this EFI bud,Thank you so much for your patience Sir
