Solved stuck at End random seed please help
santosh mareddy
Build Spec
  • CPU: AMD Ryzen 9 5900X
  • Motherboard: Asus STRIX X570-E
  • RAM: Gskill Ripjaws 64 GB
  • Graphics: MSI Gtx 980Ti
santosh mareddy
now I can't able to view or select pen drive in the bootloader to install OSX
Replace the config with this one.
  • Config.plist
Did you copy the bios settings. Mainly csm and legacy usb? Try enabling legacy usb again unless @AudioGod has another idea.
santosh mareddy
Its not working sir
AudioGod
Its not working sir
If you are using my EFI I have the recovery drive that I’m guessing your trying to use hidden as standard.
when you get to the bootpicker press space to reveal the recovery drive.
santosh mareddy
thank you for the rep[y audioGod But now am having error like this
That shouldn't appear as verbose is enabled. Try this
  • Config.plist
santosh mareddy
AudioGod
What version MacOS are you trying to install?
AudioGod
High Sierra
Ahhh ok that’s explains it.
My EFI won’t work with anything older then Catalina.
It need converting from SMBios MacPro7,1 to iMacPro1,1
Give me a few minutes and I will adapt it for you.
BRB
santosh mareddy
Thank you so much for your patience Sir
AudioGod
Try this EFI bud,
I have added SMBIOS details for you so all you need todo is drop the new EFI into your USB Installers EFI Partition and boot up and Try and Install High Sierra.
Should work now ;)
  • Asus X570-E 071 Hig Sierra EFI .zip
AudioGod
Made a mistake and corrected it so if you downloaded the EFI like 2 mins ago download it again. whoops lol
santosh mareddy
Something is gone wrong brother
