Typo, lol, Try Now. Sorry im not on it today lolSomething is gone wrong brother
am on windows how to add this sirIf itās still not having it then try adding nv_disable=1 to the boot arguments..
If you can get to the installer main page like you are then the problem isnāt the EFI or you wouldnāt be able to get that far.I tried it installing again but stuck at the same point
its ok sir I will check it by my self, thank you for helping out in creating EFIIf you can get to the installer main page like you are then the problem isnāt the EFI or you wouldnāt be able to get that far.
Everytime I have seen a usb installer doing what yours is doing it has been due to the USB installer being created via windows incorrectly.
Its the one thing I canāt do anything about from here Iām afraid.
yes i am, but nothing workingYou're clicking continue after selecting to install right? Or double click the install option.
You need to install the web Drivers for your card.Got everything up and running but am facing big issue with my graphic card its showing only 8mb
its not working sirYou need to install the web Drivers for your card.
Quadro & GeForce macOS Driver Release 378.10.10.10.15.114 | 378.10.10.10.15.114 | | NVIDIA
Download the English (US) Quadro & GeForce macOS Driver Release 378.10.10.10.15.114 for systems. Released 2017.9.27www.nvidia.com
In the config.plist under NVRAM you need to remove the boot argument nv_disable=1 before installing the drivers and in the config.plist under Misc-> Security set SecureBootModel to Disabled instead of j137.
Thats it
