Solved stuck at End random seed please help
Build Spec
  • CPU: AMD Ryzen 9 5900X
  • Motherboard: Asus STRIX X570-E
  • RAM: Gskill Ripjaws 64 GB
  • Graphics: MSI Gtx 980Ti
Replace the config with this one.
  • Config.plist
If you are using my EFI I have the recovery drive that I’m guessing your trying to use hidden as standard.
when you get to the bootpicker press space to reveal the recovery drive.
thank you for the rep[y audioGod But now am having error like this
That shouldn't appear as verbose is enabled. Try this
  • Config.plist
AudioGod
Thank you so much for your patience Sir
Try this EFI bud,
I have added SMBIOS details for you so all you need todo is drop the new EFI into your USB Installers EFI Partition and boot up and Try and Install High Sierra.
Should work now ;)
  • Asus X570-E 071 Hig Sierra EFI .zip
AudioGod
Made a mistake and corrected it so if you downloaded the EFI like 2 mins ago download it again. whoops lol
