Hi , i've fixed it out, removed the intel wifi module, it conflicts with bcm94360Should be working bud, it’s mapped right that’s for sure or it wouldn’t be listed. The bcm93640CD might very well need BrcmPatchRAM and or AirportBrcmFixup to make it work correctly with Big Sur.
GitHub - acidanthera/BrcmPatchRAM
Contribute to acidanthera/BrcmPatchRAM development by creating an account on GitHub.github.com
Hi AudioGod,This is my first fully functional Ryzen Hackintosh after many many years of intel builds and when I say fully functional I mean just that.
Everything is working bar SideCar of course as there's no IGPU and I'm using SMBios iMacPro1,1 but as for everything else goes like proper sleep, Wake, All iCloud functions, Handoff, AppleWatch Unlock etc etc all works beautifully.
I have fully mapped out USB manually on all ports and there's no micro stutters or freezes or anything else strange that you can think of.
Build Spec
- CPU: Ryzen 9 5900X
Motherboard: Gigabyte AORUS X570 Pro (Bios Revision - F33a) RAM: Corsair Pro Vengeance 32GB DDR4 3600Mhz (Tuned) Graphics: Sapphire RX 5700 XT Case : Lian Li PC-O11DW Dynamic. NVMe: Samsung 970 EVO 1TB & Samsung 970 EVO Plus 1TB SSD: Samsung 860 EVO 1TB HDD: Seagate Barracuda 1TB PSU: EVGA SuperNOVA 850 G5, 80 Plus Gold 850W WiFi-Bluetooth: ABWB BCM94360CS2 802.11AC WI-FI With Bluetooth 4.0 PCIe Sound: Onboard & Native Instruments Audio 6 Cooling : Arctic Liquid Freezer II 360 AIO Installed Operating Systems: Big Sur 11.4 - Windows 10 Pro Bootloader: OpenCore 0.7.0
ACPI SSDT's
- SSDT-USBX (USB power tables)
- SSDT-PLUG (CPU power management)
- SSDT-SBRG (Correcting EC, RTC memory & IRQ conflicts)
- SSDT-SBUS-MCHC (SMBus Support)
- SSDT-XHC (USB rename's)
Kexts
- Lilu
- VirtualSMC
- WhateverGreen
- AppleALC
- SmallTreeIntel82576
- AMDRyzenCPUPowerManagement
- SMCAMDProcessor
- USBMap
What WorksSound including the case's front headphones 3.5mm portEthernet PortView attachment 2013WiFi / BluetoothUSB Type C, 3.0 & 2.0 (All ports Mapped & Open)AirDropiCloudHardware AccelerationiMessagesFacetimeSleep & WakeSleep and Shutdown via the Power ButtonPower NapHandoffNetflix on Safari browserContinuityApple Watch UnlockWhat Doesn't WorkSideCarBios Settings
- Enter BIOS -> Press Delete -> Enter Setup
- Save & Exit -> Load Optimized Defaults
- Boot -> CSM Support -> Disabled
- Boot -> Fast boot -> Disabled
- Boot -> Secure boot -> Disabled
- Settings -> IO Ports -> Above 4G Decoding -> Disabled
- Settings -> IO Ports -> USB Configuration -> Legacy USB Support -> Auto
X570 Master users need to add the LucyRTL8125Ethernet.kext to the kext folder and config.plist to enable the 2.5gb Ethernet port that can be downloaded from here.
EFI Install Notes
Using PlistEdit Pro add your details by modifying the following
Note - If your not using a 5700 XT or any other Navi GPU then remove agdpmod=ignore from the boot arguments.
Realtek 2.5gb Ethernet Kext (LucyRTL8125Ethernet.kext)
The LucyRTL8125Ethernet.kext has been updated to version 1.1.0 with the following changes. Updated Linux sources to 9.005.01. Fixed auto-negotiation for all speeds (including 2.5 Gigabit). Added support for adaptive poll interval in 2.5 Gigabit...forum.amd-osx.com
If you need help then feel free to get in touch and do let me know how my EFI works for you.
Changes made include,
- SMBIOS Changed to MacPro 7,1
- Lilu 1.5.4,
- AppleALC 1.6.2,
- WhateverGreen 1.5.1,
- VirtualSMC 1.2.5,
- RestrictEvents 1.0.3,
- OpenCore Updated to Revision 0.7.1 (Big Sur 11.5 Ready),
- AMD Patches Monterey 12.0 Beta1 Compatible,
- SIP Can now be toggled within OpenCanopy,
- OpenCanopy Icons Updated,
- Plus other minor tweaks and changes to the config.
IMPORTANT SMBIOS CHANGE - As requested by many the SMBIOS has now been switched over to MacPro7,1 if you want to continue using iMacPro1,1 then all you need todo is replace the USBMap.kext with the 1,1 version and add SSDT-XHC to your ACPI and your Config.plist, Change agdpmod=ignore into agdpmod=pikera and add your 1,1 details. I will add a 1,1 conversion kit to download incase you need it.
Make sure you sign out of all icloud services before swapping over to the 7,1 EFI and Do not try and carry across your old 1,1 details to SMBIOS 7,1. You will need to create new Personal SMBIOS Details for MacPro7,1.
If you are using your real UUID and MAC address from your motherboard then these can carry over but not the Serial Number and MLB, These will need to be regenerated.
Note - If you are using a 6 or Less Core Ryzen then go into the Config,plist and under PlatformInfo->Generic Change the ProcessorType from 0 to 1537, This will list your CPU info correctly inside About This Mac.
Note 2 - The SmallTreeIntel82576.kext is not working under Monterey 12.0 so if you plan on playing around with the new OS for now make sure you use the 2.5GHz ethernet port or WiFi instead.
Current EFI - OpenCore 0.7.1 (05/07/2021) SMBIOS MacPro7,1
Did you do a legacy install of windows as it should show instantly if it was a UEFI Install?Hi AudioGod,
I put this EFI into my existing one and worked like a charm. Thank you so much.
A couple of things, the resolution is fine when it boots and the apple logo shows but the login screen is gigantic. But once logged in the resolution is fine. Then, sometimes after log in there is a blank black screen for a few seconds and then the apps start showing up. The other thing is I lost audio. Also, now OC 0.7.1 does not recognise my Windows drive (I made the necessary changes to the BIOS like disabling Secure Boot etc).
Could you give me some hints as to where I could go looking to fix these? What could be the things I would look like, kexts ? something else?
My machine is
ASUS Pro WS X570-ACE
Ryzen 9 3900X
32GSs RAM
2 500 GB SSDs
Well, I yolo'd the update from Catalina to Big Sur through the App Store and everything is working lol, so I guess I'm good for nowHey! I‘ve just recently made my first Hackintosh installation ever all by myself using Dortania’s guide, and everything went smooth (for the most part). But I did it with MacOS Catalina! And I really want to have 11.5 Big Sur.
My system:
MOBO: Gigabyte X570 Aorus Elite
CPU: Ryzen 5 3600
GPU: RX 5700
RAM: 32GB
Do you think I can use your EFI files to set myself up?
I don’t care about Wi-Fi or Bluetooth and the benefits that comes with them at all for now. I use internet via ethernet and I don’t have any plans to buy a Wi-Fi card at the moment. Just telling you in case that matters. Using SmallTreeIntel82576.kext the internet is working fine right now on Catalina.
Also, do I need to create a new USB with Big Sur (and your EFI) on it and delete everything (fully reinstall OS) to upgrade to Big Sur? Or is there a way for me to upgrade from Catalina without problems? (I have the notification from App Store telling me that Big Sur 11.5 is available).
Thank you so much for your help![]()
Sorry buddy I missed your post from earlier.Well, I yolo'd the update from Catalina to Big Sur through the App Store and everything is working lol, so I guess I'm good for now![]()
I am actually not sure. I just used the Windows installer. It was showing when I was on OC 0.7.0 but not after upgrade to 0.7.1. The windows installer USB shows up. I shall check again, thanks for the hint. Oh and I figured out the audio, if I make it alcid=1 , seems works for my motherboard. I compare carefully with the older config.plist. My resolution issues are not 100% fixed but better. I removed adgpmod=ignore but I am not sure I should do that.Did you do a legacy install of windows as it should show instantly if it was a UEFI Install?
AudioGod: Thank you so much for posting this and helping out the community members. My research has found some people having issues with hardwired ethernet drop outs and of course software issues (ie. Adobe and Zoom). Have you experienced any of these issues with this build?This is my first fully functional Ryzen Hackintosh after many many years of intel builds and when I say fully functional I mean just that.
Build Spec
ACPI SSDT's
Kexts
- Lilu
- VirtualSMC
- WhateverGreen
- AppleALC
- SMCAMDProcessor
- USBMap
EFI Install Notes
- Lilu 1.5.4,
- AppleALC 1.6.2,
- VirtualSMC 1.2.5,
Monterey Beta1 is the only version that will work with the current patches inside my 0.7.1 EFI. The new patches are not ready yet but if you want to get the latest beta working then follow Professor Shaneee’s steps on how to get it going.And I dabbled with Monterey which I downloaded by signing up for the beta program. That gest stuck at the apple logo, I left it overnight and there was no movement.
No issues with any hardware including Ethernet and WLAN, Everything is rock solid.AudioGod: Thank you so much for posting this and helping out the community members. My research has found some people having issues with hardwired ethernet drop outs and of course software issues (ie. Adobe and Zoom). Have you experienced any of these issues with this build?
I see you did upgrade to RX 6000 series also.Bit Quick for a update but again No Problems![]()
Welcome to the Big Navi Club BruvI see you did upgrade to RX 6000 series also.![]()
2021-07-29 19:45:11.053111+0530 0x8ac Default 0x0 0 0 kernel: (AppleTopCaseHIDEventDriver) [HID] [ATC] AppleDeviceManagementHIDEventService:rocessWakeReason Wake reason: Button (0x03)
2021-07-29 19:45:21.587843+0530 0x7d6 Default 0x0 219 0 airportd: systemWokenByWiFi: System Wake Reason not found
2021-07-29 19:45:28.800284+0530 0x7d6 Default 0x0 219 0 airportd: systemWokenByWiFi: System Wake Reason not found
2021-07-29 19:45:28.804120+0530 0x7d6 Default 0x0 219 0 airportd: systemWokenByWiFi: System Wake Reason not found
2021-07-29 19:45:28.904085+0530 0xe15 Default 0x0 219 0 airportd: systemWokenByWiFi: System Wake Reason not found
2021-07-29 19:45:46.613819+0530 0x1978 Default 0x0 219 0 airportd: systemWokenByWiFi: System Wake Reason not found
2021-07-29 19:46:34.614571+0530 0x1c61 Default 0x0 219 0 airportd: systemWokenByWiFi: System Wake Reason not found
2021-07-29 19:50:37.082299+0530 0x212d Default 0x0 85 0 powerd: [powerd:sleepWake] Wake reason: "<private>" identity: "<private>"
2021-07-29 19:50:57.332059+0530 0x75 Default 0x0 0 0 kernel: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: GPP2 GPP3 GPP4 GPP5 GPP6 GPP7 GPP9 GPPA GPPB GPPC GPPD GPPE GPPF GP10 GP11
2021-07-29 19:50:57.332060+0530 0x75 Default 0x0 0 0 kernel: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: GPP2 GPP3 GPP4 GPP5 GPP6 GPP7 GPP9 GPPA GPPB GPPC GPPD GPPE GPPF GP10 GP11
2021-07-29 19:51:00.706890+0530 0x24d3 Default 0x0 0 0 kernel: (AppleTopCaseHIDEventDriver) [HID] [ATC] [Error] AppleDeviceManagementHIDEventService::getWakeReason Could not get wake reason (reportID = 0xc5, Return Value = 0xe00002c2)
2021-07-29 19:51:00.708794+0530 0x2410 Default 0x0 85 0 powerd: [powerd:sleepWake] Wake reason: "<private>" identity: "<private>"
2021-07-29 19:51:29.687027+0530 0x2748 Default 0x0 0 0 kernel: (AppleTopCaseHIDEventDriver) [HID] [ATC] AppleDeviceManagementHIDEventService:rocessWakeReason Wake reason: Button (0x03)
2021-07-29 20:01:12.693964+0530 0x7e2 Default 0x0 191 0 airportd: systemWokenByWiFi: System Wake Reason not found
2021-07-29 20:01:14.397168+0530 0x8d3 Default 0x0 0 0 kernel: (AppleTopCaseHIDEventDriver) [HID] [ATC] AppleDeviceManagementHIDEventService:rocessWakeReason Wake reason: Button (0x03)
2021-07-29 20:01:23.405377+0530 0xaff Default 0x0 191 0 airportd: systemWokenByWiFi: System Wake Reason not found
2021-07-29 20:01:27.332576+0530 0xaff Default 0x0 191 0 airportd: systemWokenByWiFi: System Wake Reason not found
2021-07-29 20:01:27.443063+0530 0x7e0 Default 0x0 191 0 airportd: systemWokenByWiFi: System Wake Reason not found
2021-07-29 20:01:32.630914+0530 0x3e8 Default 0x0 85 0 powerd: [powerd:sleepWake] Wake reason: "<private>" identity: "<private>"
2021-07-29 20:01:51.838073+0530 0x75 Default 0x0 0 0 kernel: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: GPP2 GPP3 GPP4 GPP5 GPP6 GPP7 GPP9 GPPA GPPB GPPC GPPD GPPE GPPF GP10 GP11
2021-07-29 20:01:51.838074+0530 0x75 Default 0x0 0 0 kernel: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: GPP2 GPP3 GPP4 GPP5 GPP6 GPP7 GPP9 GPPA GPPB GPPC GPPD GPPE GPPF GP10 GP11
2021-07-29 20:01:54.715423+0530 0xd11 Default 0x0 0 0 kernel: (AppleTopCaseHIDEventDriver) [HID] [ATC] [Error] AppleDeviceManagementHIDEventService::getWakeReason Could not get wake reason (reportID = 0xc5, Return Value = 0xe00002c2)
2021-07-29 20:01:54.717372+0530 0xc2c Default 0x0 85 0 powerd: [powerd:sleepWake] Wake reason: "<private>" identity: "<private>"
2021-07-29 20:02:11.134966+0530 0xda9 Default 0x0 0 0 kernel: (AppleTopCaseHIDEventDriver) [HID] [ATC] AppleDeviceManagementHIDEventService:rocessWakeReason Wake reason: Button (0x03)
2021-07-29 20:02:47.588079+0530 0x343 Default 0x0 113 0 apsd: [com.apple.apsd:stream] Checking for wake reason address <private> from <private>
2021-07-29 20:02:47.588089+0530 0x343 Default 0x0 113 0 apsd: [com.apple.apsd:stream] Found potential wake reason (null)
2021-07-29 20:02:47.588098+0530 0x343 Default 0x0 113 0 apsd: [com.apple.apsd:stream] Found potential wake reason (null)
2021-07-29 20:02:47.589080+0530 0x343 Default 0x0 113 0 apsd: [com.apple.apsd:stream] Checking for wake reason address <private> from <private>
2021-07-29 20:02:47.589088+0530 0x343 Default 0x0 113 0 apsd: [com.apple.apsd:stream] Found potential wake reason (null)
2021-07-29 20:02:47.589095+0530 0x343 Default 0x0 113 0 apsd: [com.apple.apsd:stream] Found potential wake reason (null)
2021-07-29 20:02:47.833768+0530 0x343 Default 0x0 113 0 apsd: [com.apple.apsd:stream] Checking for wake reason address <private> from <private>
2021-07-29 20:02:47.833777+0530 0x343 Default 0x0 113 0 apsd: [com.apple.apsd:stream] Found potential wake reason (null)
2021-07-29 20:02:47.833787+0530 0x343 Default 0x0 113 0 apsd: [com.apple.apsd:stream] Found potential wake reason (null)
Your Corsair AIO breaks sleep as does any corsair hardware using a internal usb connection. There’s two ways around it.Hi @AudioGod,
I'm having issues with sleep/wake. as soon as i click to sleep, display goes off and after few sec system too but immediately system power back without display, if i try to activate display by clicking to keyboard/mouse it takes few seconds for display to work again. though my display connected with HDMI and it comes with speaker which don't show after wake from sleep sometimes. i tried to debug wake reason, below is log, any help appreciated. wake for wifi & power nap disabled.
Thanks but still after 2 or 3 sleep my display audio not shows anymore under macos, only restarts fix it. Display connected using HDMI, Any solution?Your Corsair AIO breaks sleep as does any corsair hardware using a internal usb connection. There’s two ways around it.
1, disconnect the usb internal header for the AIO from the motherboard as you don’t need it connected at all once it’s setup the way you want it windows.
If you don’t want to do that then,
2, You need to add a ssdt and patch to OpenCore so USB doesn’t cause the system to wake. I do not using this method but works with a small price of not being able to use your keyboard or mouse to wake the system but instead you have to use the cases power button to wake it up.
https://dortania.github.io/OpenCore-Post-Install/usb/misc/instant-wake.html
The correct method of the 3 listed is the first one (GPRW to XPRW)
Try clearing your NVRam.Thanks but still after 2 or 3 sleep my display audio not shows anymore under macos, only restarts fix it. Display connected using HDMI, Any solution?
