Solved stuck at End random seed please help
AudioGod
  • Asus X570-E 071 Hig Sierra EFI .zip
santosh mareddy
Now it stuck at apple logo forever sir 😅
AudioGod
lol getting closer..
Make sure Above 4g is disabled in the bios
and try now
AudioGod
BIOS Settings
  • Ai Tweaker -> Ai Overclock Tuner -> D.O.C.P.
  • Advanced -> PCI Subsystem Settings -> Above 4G Decoding -> Disabled
  • Advanced -> USB Configuration -> Legacy USB Support -> Auto
AudioGod
If it’s still not having it then try adding nv_disable=1 to the boot arguments..
santosh mareddy
Nothing is working when i click here here sir
am on windows how to add this sir
santosh mareddy
now nothing is working here when I click something it does nothing sir
AudioGod
That fault you have now tends to mean that your USB installer is incorrect.
most common fault is creating the installer in windows and getting the format wrong.
you might need to remake the installer.
il make the change to the EFI now anyway but it’s unrelated to the fault you have now.
AudioGod
EFI with added boot argument nv_disable=1
I think the last version I sent you is correct though.
Its that one or this one.
Still though your USB Installer seems borked.
Make sure when you format the USB Stick that its using a GUID Partition Map and not Fat32 etc
santosh mareddy
I tried it installing again but stuck at the same point
AudioGod
If you can get to the installer main page like you are then the problem isn’t the EFI or you wouldn’t be able to get that far.
Everytime I have seen a usb installer doing what yours is doing it has been due to the USB installer being created via windows incorrectly.
Its the one thing I can’t do anything about from here I’m afraid.
I will try one more thing now for you but I doubt it will make any difference.
brb
santosh mareddy
its ok sir I will check it by my self, thank you for helping out in creating EFI
AudioGod
Corrected EFI number god knows lol
Its exactly the same bar one change to a Kext that was not compatible with High Sierra, I don't think it will make any difference but it is a needed correction anyway. :)
You're clicking continue after selecting to install right? Or double click the install option.
santosh mareddy
yes i am, but nothing working
It can sometimes take a few mins, it doesn't always load instantly.
santosh mareddy
Got everything up and running but am facing big issue with my graphic card its showing only 8mb
AudioGod
You need to install the web Drivers for your card.
In the config.plist under NVRAM you need to remove the boot argument nv_disable=1 before installing the drivers and in the config.plist under Misc-> Security set SecureBootModel to Disabled instead of j137.
Thats it
santosh mareddy
Thats it
its not working sir
Update to the latest version of High Sierra first. Then go to about this Mac and click on the version. It'll now show the build number. 17G14042 should be the latest but let me know what you get and I'll link the web driver for it. Each build requires a different version.
