sonoma problem
AliKurt1337
The situation is as follows, I have monterey booting fine on this bootloader, but when I try to update or install a clean sonoma the bootloader just stops, and no problems are detected by debug
  • opencore-2023-11-01-233308.txt
RyzeCooker
Which version of OpenCore? Latest cpu patches? All kexts updated? Monterey > Sonoma is a big jump and things need to be updated, especially the cpu patches.
What system are you using? Motherboard, CPU, dGPU, WiFi/BT, Ethernet etc?
Without this information it is nearly impossible to tell what is correct and what is wrong with your OC setup. As a quick review of your config.plist doesn't show anything untoward.
AliKurt1337
I've seen similar situations on the forum, but I never realized whether he solved them or not.
Try this OpenCore 0.9.5 EFI.
See if this gets you any further after the Verbose Text has finished.
I am assuming you have set your bios correctly, i.e. used the settings shown in the link below to configure your system bios.
# AMD Bios Settings
  • I have set Booter > Quirks > ResizeAppleGpu Bars to '0'.
  • I have not added the npci=0x3000 boot argument.
AliKurt1337
# AMD Bios Settings
I tried with your efi - the result is the same, both on Install Sonoma and on Mac install, with Monterey logged in normally
I also attach bios settings, maybe I made a mistake somewhere.
The Bios settings shown in the screenshots above look ok.
