The situation is as follows, I have monterey booting fine on this bootloader, but when I try to update or install a clean sonoma the bootloader just stops, and no problems are detected by debug
oc 0.9.5Which version of OpenCore? Latest cpu patches? All kexts updated? Monterey > Sonoma is a big jump and things need to be updated, especially the cpu patches.
I've seen similar situations on the forum, but I never realized whether he solved them or not.What system are you using? Motherboard, CPU, dGPU, WiFi/BT, Ethernet etc?
Without this information it is nearly impossible to tell what is correct and what is wrong with your OC setup. As a quick review of your config.plist doesn't show anything untoward.
I tried with your efi - the result is the same, both on Install Sonoma and on Mac install, with Monterey logged in normallyTry this OpenCore 0.9.5 EFI.
See if this gets you any further after the Verbose Text has finished.
I am assuming you have set your bios correctly, i.e. used the settings shown in the link below to configure your system bios.
# AMD Bios Settings
- I have set Booter > Quirks > ResizeAppleGpu Bars to '0'.
- I have not added the npci=0x3000 boot argument.
That's the problem, it's not him.The Bios settings shown in the screenshots above look ok.
