Ryzen Threadripper TRX50
backinblackx86
57
52
18
Risen 7950x
I am intending on building a new workstation. I have a 7960x AMD Ryzen Zen 4 Threadripper. The motherboard available in my local area is a Gigabyte TRX50 AERO D and I also have an AMD 6800 XT gpu from a previous MacOS build. Thoughts?
See page four of the manual (link below) to view the block diagram of the motherboard.
  1. The Intel USB4 controller might be the biggest issue on that motherboard.
    1. As only a few Apple Silicon MacBookPro/Air systems have Thunderbolt/USB4 controllers and they are not likely to be the same as your Intel USB4 controller.
    2. Not sure it is supported, so anything connected via the USB4 controller will also be suspect in macOS. Until proven otherwise.
  2. Not sure what level of Kernel Patching the Zen 4 Threadripper will require, it could be the current AMD Kernel Patches work.
    1. It won't exceed the max number of Cores/Threads allowed in macOS at 24/48 respectively.
  3. You will probably end up doing a bit of trial and error testing, regarding the Boot > Quirks in the config.plist, to get the correct combination so the system boots.
I have not attempted to make an AMD-OSX system since Zen1 1600X on High Sierra. Exciting challenge.
32/64 like old threadripper in latest OSX is the real limit
problems could be more complex and this could involve, as in the past ,a big modify on the openruntime.efi
Old patches worked well in threadripper trx40 (opencore devs said that patches were borked but it was memory manager which failed)
interesting try :)
i would start with an old EFI based on trx40 parameter and post a debug log
This time last year I was closely following the x670E AM5 work of CaseySJ and others of this forum and intended on participating but the components I had access to were used for a Linux web-server. I am glad there is interest and enthusiasm for this TRX50 endeavor and rest assured, I have on hand all the parts necessary for this build including but not limited to, Motherboard, PSU, CPU plus heatsink, compatible GPU, R-DIMM DDR5, and 5.0 NvME. I will provide photographs as the build proceeds. The case I will be using has not seen a new build since 2013 consisting of a Intel i7 3770k, 32Gb DDR3 1600MHz, hosted on a GA-Z77x-UD5H with Nvidia 680 2Gb. Cheers!
Don't use a Samsung NVME drive, as they are known to be problematic when used as a boot drive for macOS. A SanDisk or Western Digital NVME drive would be ideal, as they both work in macOS.
Using an old case may limit the USB Ports available on the front of the case, specifically the lack of a Type-C port.
Your TRX50 motherboard has the following Internal headers.
  • 1 x USB Type-C® port with USB 3.2 Gen 2x2 support, available through the internal USB header
  • 2 x USB 3.2 Gen 1 ports available through the internal USB header
  • 4 x USB 2.0/1.1 ports available through the internal USB headers
The Qualcomm WiFi/BT card won't work in macOS. You will need to swap this for an Intel WiFi/Bt card, something like the AX210 would work.
Both Ethernet ports should work with the correct Kexts, or config.plist settings.
The Audio on this board is split front and back. So you may have to choose one or the other to be disabled. I am not sure if AppleALC.kext will activate both the front ALC897 codec and the rear ALC4080 codec (possibly USB audio). If the rear Audio is USB connection then it will need AppleALCU.kext.
I would also recommend installing Monterey or Ventura first, as they are easier to get running than Sonoma. It is simple to upgrade to Sonoma once you have macOS installed.
Yes, I am aware of the Samsung issue and do have on hand both Crucial and WD NvME’s.
Case wise, I understand that this 2006-era case is limited as compared to the modern Lian-Li and Corsair cases of my most recent server builds but perhaps its Volkswagen air-cooled type2 transporter bus inspired charm will win your heart. It is a Cooler Master Stacker 830 I bought off Amazon years ago and it has traveled many miles with me as a video-editing and digital audio workstation
I certainly do not expect the Qualcomm “Wi-Fi 7“ to function, neither is it a necessity for my specific use case but I do have a spare PCI-E x4 card on-hand with a Broadcom 802.11 AC “Wi-fi 5” chip that worked well in Mojave. My experience with the more modern onboard Intel Wifi as included with Z690 and Z590 Intel motherboards was positive, however, so I may consider such a task of swapping that component if deemed necessary.
I do have two spare GPU’s for testing purposes, an AMD RX 560 and the oldie-but-goodie GeForce 680. The AMD 6800 XT & 6600 XT I have are both in active use in other systems at the moment both feeding 12 Bit RGB HDR monitors…using Windows of all things. The four 7950x systems I built this past year are all running Linux as 24/7 web servers and are rock solid. Therefore when it came time to upgrade my own aging 3rd Intel, I naturally chose Zen4. Although Intel was considered, I never was entirely happy with my 12900 Z690 DDR5 build, neither operating Windows or MacOS, Linux performed fine though.
Reactions: Edhawk and fabiosun
Just mounted the motherboard….CPU and heatsink to follow…
Okay the system is built and has posted to the BIOS…
I will pick back up on this project in the next few days…
I admire your patience and calm
I would not have lasted all this time without trying my trx40 a few years ago🥹
Thread could be useful also for you but you could have additional problem with new dsdt of your motherboard
Very curious about your OSX tries
I have yet to make progress on this…but as a warm up I setup an Intel 2600k and intend on practicing the Ryzen patches on a Zen1 1600x.
I pulled two Crucial T700’s from another system, one has a Linux installation and the other is unused. May we proceed. Also in my research, I came across this forum thread on TRX40 bare metal: https://macos86.it/topic/3307-discussion-trx40-bare-metal-vanilla-patches/page/155/
T700 both in 2 and 4TB has given me a lotta headaches on my Trx40. The Z540 works mostly well, though random restarts soon after booting are not uncommon. Though once it passes a one minute mark after reaching desktop, the system is pretty solid - so I suggest go with the WD or other crucial drives.
Also, assuming (really hoping) you can boot macOS on this, will it be possible to get it running on wrx90 system too? Since TR pros from 3000 and 5000 were kinda never hackintoshed
I have been reading over the AM5 Guides, assuming there are some similarities. It has been a long time since I have even attempted an AMDx86 MacOS. I feel I have dragged my feet on this project but I found it necessary to rebuild the simpler systems first.
Reactions: etorix
Not TRx related, but I brought an AM4 B550m system online today booting Ventura, may attempt the Sonoma update. I am at least now more refreshed on the process.
Reactions: Edhawk
Okay I am booted into Linux and am in the process of identifying the hardware....
grep -i "model name" /proc/cpuinfo
model name : AMD Ryzen Threadripper 7960X 24-Cores
lspci | grep -i --color "vga\|3d\|2d"
81:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Baffin [Radeon RX 550 640SP / RX 560/560X] (rev cf)
dmidecode -t baseboard
# dmidecode 3.3
Getting SMBIOS data from sysfs.
SMBIOS 3.6.0 present.
# SMBIOS implementations newer than version 3.5.0 are not
# fully supported by this version of dmidecode.
Handle 0x0002, DMI type 2, 15 bytes
Base Board Information
Manufacturer: Gigabyte Technology Co., Ltd.
Product Name: TRX50 AERO D
Version: x.x
Serial Number: Default string
Asset Tag: Default string
Features:
Board is a hosting board
Board is replaceable
Location In Chassis: Default string
Chassis Handle: 0x0003
Type: Motherboard
Contained Object Handles: 0
Handle 0x0004, DMI type 10, 6 bytes
On Board Device Information
Type: Video
Status: Enabled
Description: To Be Filled By O.E.M.
Handle 0x003A, DMI type 41, 11 bytes
Onboard Device
Reference Designation: Onboard LAN AQC107
Type: Ethernet
Status: Enabled
Type Instance: 1
Bus Address: 0000:43:00.0
Handle 0x003B, DMI type 41, 11 bytes
Onboard Device
Reference Designation: Chipset SATA
Type: SATA Controller
Status: Enabled
Type Instance: 5
Bus Address: 0000:6d:00.0
aplay -l
** List of PLAYBACK Hardware Devices **
card 0: HDMI [HDA ATI HDMI], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: HDMI [HDA ATI HDMI], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: HDMI [HDA ATI HDMI], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: HDMI [HDA ATI HDMI], device 9: HDMI 3 [ASUS PB278]
Subdevices: 1/1
card 0: HDMI [HDA ATI HDMI], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 1: Audio [USB Audio], device 0: USB Audio [USB Audio]
Subdevices: 1/1
card 2: Generic [HD-Audio Generic], device 0: ALC897 Analog [ALC897 Analog]
Subdevices: 1/1
lshw -class network
*-network
description: Ethernet interface
product: Aquantia Corp.
vendor: Aquantia Corp.
physical id: 0
bus info: pci@0000:43:00.0
logical name: eno1
version: 03
serial: 74:56:3c:ba:32:ed
capacity: 10Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list rom ethernet physical tp 10bt-fd 100bt-fd 1000bt-fd 10000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=atlantic driverversion=6.6.6-76060606-generic firmware=1.3.7 latency=0 link=no multicast=yes port=twisted pair
resources: irq:26 memory:90800000-9087ffff memory:908a0000-908a0fff memory:90400000-907fffff memory:90880000-9089ffff
*-network UNCLAIMED
description: Network controller
product: Qualcomm
vendor: Qualcomm
physical id: 0
bus info: pci@0000:44:00.0
version: 01
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress cap_list
configuration: latency=0
resources: memory:90a00000-90bfffff
*-network
product: RTL8125 2.5GbE Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:45:00.0
logical name: enp69s0
version: 05
serial: 74:56:3c:ba:32:ec
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=6.6.6-76060606-generic duplex=full firmware=rtl8125b-2_0.0.2 07/13/20 ip=192.168.50.152 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:52 ioport:1000(size=256) memory:90e00000-90e0ffff memory:90e10000-90e13fff
lshw -class disk -class storage
*-nvme
description: NVMe device
product: CT4000T700SSD3
vendor: Micron/Crucial Technology
physical id: 0
bus info: pci@0000:01:00.0
logical name: /dev/nvme0
version: PACR5102
serial: 2339E8796BD7
width: 64 bits
clock: 33MHz
capabilities: nvme pciexpress vpd msix msi pm nvm_express bus_master cap_list
configuration: driver=nvme latency=0 nqn=nqn.2016-08.com.micron:nvme:nvm-subsystem-sn-2339E8796BD7 state=live
resources: irq:85 memory:f2600000-f2603fff
*-namespace:0
description: NVMe disk
physical id: 0
logical name: hwmon1
*-namespace:1
physical id: 2
logical name: /dev/ng0n1
*-namespace:2
physical id: 1
bus info: nvme@0:1
logical name: /dev/nvme0n1
capabilities: gpt-1.00 partitioned partitioned:gpt
configuration: guid=56758df1-63e1-4b49-b704-153e529f2d64 logicalsectorsize=512 sectorsize=512 wwid=uuid.5e7980c1-15e7-491e-9023-8c1cd97a9592
*-nvme
physical id: 0
bus info: pci@0000:02:00.0
logical name: /dev/nvme1
version: PACR5102
serial: 2340E87BB2B6
width: 64 bits
clock: 33MHz
configuration: driver=nvme latency=0 nqn=nqn.2016-08.com.micron:nvme:nvm-subsystem-sn-2340E87BB2B6 state=live
resources: irq:87 memory:f2500000-f2503fff
*-namespace:0
physical id: 0
logical name: hwmon0
*-namespace:1
physical id: 2
logical name: /dev/ng1n1
*-namespace:2
physical id: 1
bus info: nvme@1:1
logical name: /dev/nvme1n1
configuration: guid=0113114b-9c3d-4830-8866-d23b7f28601a logicalsectorsize=512 sectorsize=512 wwid=uuid.5730c59b-4db1-420d-a91d-4c991eb75866
*-usb
description: Mass storage device
product: Mass Storage
vendor: Generic
physical id: 4
bus info: usb@7:a.4
version: 1.03
serial: 4D1D2709
capabilities: usb-2.00 scsi
configuration: driver=usb-storage maxpower=100mA speed=480Mbit/s
*-sata
description: SATA controller
product: Advanced Micro Devices, Inc. [AMD]
vendor: Advanced Micro Devices, Inc. [AMD]
physical id: 0
bus info: pci@0000:6d:00.0
version: 01
width: 32 bits
clock: 33MHz
capabilities: sata msi pm pciexpress ahci_1.0 bus_master cap_list rom
configuration: driver=ahci latency=0
resources: irq:79 memory:90c80000-90c803ff memory:90c00000-90c7ffff
*-scsi
physical id: 1
bus info: usb@7:10.4
logical name: scsi6
capabilities: emulated scsi-host
*-disk
description: SCSI Disk
product: Flash Disk
vendor: Generic
physical id: 0.0.0
bus info: scsi@6:0.0.0
logical name: /dev/sda
version: 8.07
capabilities: removable
configuration: ansiversion=2 logicalsectorsize=512 sectorsize=512
*-medium
physical id: 0
configuration: guid=0b5a3c15-d9cc-43af-8c52-5ea82a5f19ed
lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14a4 (rev 01)
00:00.3 Generic system peripheral [0807]: Advanced Micro Devices, Inc. [AMD] Device 14a6
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 149f (rev 01)
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14ab (rev 01)
00:01.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14ab (rev 01)
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 149f (rev 01)
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 149f (rev 01)
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 149f (rev 01)
00:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 149f (rev 01)
00:05.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14aa (rev 01)
00:05.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14aa (rev 01)
00:05.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14aa (rev 01)
00:05.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14aa (rev 01)
00:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 149f (rev 01)
00:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14a7 (rev 01)
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 71)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14ad
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14ae
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14af
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14b0
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14b1
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14b2
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14b3
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14b4
01:00.0 Non-Volatile memory controller: Micron/Crucial Technology Device 5419
02:00.0 Non-Volatile memory controller: Micron/Crucial Technology Device 5419
07:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device 14ac (rev 01)
07:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Device 14c9 (rev da)
07:00.5 Encryption controller: Advanced Micro Devices, Inc. [AMD] Device 14ca
07:00.7 Audio device: Advanced Micro Devices, Inc. [AMD] Device 14cc
40:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14a4 (rev 01)
40:00.3 Generic system peripheral [0807]: Advanced Micro Devices, Inc. [AMD] Device 14a6
40:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 149f (rev 01)
40:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 149f (rev 01)
40:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 149f (rev 01)
40:03.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14a5 (rev 01)
40:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 149f (rev 01)
40:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 149f (rev 01)
40:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 149f (rev 01)
40:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14a7 (rev 01)
41:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f4 (rev 01)
42:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f5 (rev 01)
42:02.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f5 (rev 01)
42:03.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f5 (rev 01)
42:08.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f5 (rev 01)
42:0c.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f5 (rev 01)
42:0d.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f5 (rev 01)
43:00.0 Ethernet controller: Aquantia Corp. Device 14c0 (rev 03)
44:00.0 Network controller: Qualcomm Device 1107 (rev 01)
45:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller (rev 05)
46:00.0 PCI bridge: Intel Corporation Thunderbolt 4 Bridge [Maple Ridge 4C 2020] (rev 02)
47:00.0 PCI bridge: Intel Corporation Thunderbolt 4 Bridge [Maple Ridge 4C 2020] (rev 02)
47:01.0 PCI bridge: Intel Corporation Thunderbolt 4 Bridge [Maple Ridge 4C 2020] (rev 02)
47:02.0 PCI bridge: Intel Corporation Thunderbolt 4 Bridge [Maple Ridge 4C 2020] (rev 02)
47:03.0 PCI bridge: Intel Corporation Thunderbolt 4 Bridge [Maple Ridge 4C 2020] (rev 02)
48:00.0 USB controller: Intel Corporation Thunderbolt 4 NHI [Maple Ridge 4C 2020]
5a:00.0 USB controller: Intel Corporation Thunderbolt 4 USB Controller [Maple Ridge 4C 2020]
6c:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] Device 43f7 (rev 01)
6d:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] Device 43f6 (rev 01)
6e:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device 14ac (rev 01)
80:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14a4 (rev 01)
80:00.3 Generic system peripheral [0807]: Advanced Micro Devices, Inc. [AMD] Device 14a6
80:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 149f (rev 01)
80:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14ab (rev 01)
80:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 149f (rev 01)
80:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 149f (rev 01)
80:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 149f (rev 01)
80:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 149f (rev 01)
80:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 149f (rev 01)
80:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14a7 (rev 01)
81:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
82:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device 14ac (rev 01)
c0:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14a4 (rev 01)
c0:00.3 Generic system peripheral [0807]: Advanced Micro Devices, Inc. [AMD] Device 14a6
c0:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 149f (rev 01)
c0:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 149f (rev 01)
c0:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 149f (rev 01)
c0:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 149f (rev 01)
c0:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 149f (rev 01)
c0:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 149f (rev 01)
c0:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14a7 (rev 01)
c1:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device 14ac (rev 01)
c1:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Device 14c9 (rev da)
