Vielen Dank! Jetzt kann ich an einem einfachen Build-Post arbeiten und EFI testen. Werde dies tun, nachdem ich einen Patch für Ventura untersucht habe.Ganz hervorragende Leistung vielen Dank. Ich bin ein wenig raus aus dem Thema Hackintosh seid Corona. @CaseySJ Würdest du mire evtl. Deine EFI zu Verfügung stellen . Wir haben die gleiche Hardware.Danke
Unfortunately there’s no change to audio! The static still exists, but is significantly less with latest beta BIOS.@CaseySJ thank you for this great result!
May I ask if you see also audio in a perfect way with this patch?
Good question about M.2. Will check on that today as well.Unbelievable timing and incredible work bravo. I was about to pull the trigger on a 13900 build. I guess the m.2 ssd situation is solved as well ? Is a gigabyte x670 board ok to look at or go with asus?
@CaseySJ I was going to look at making it one patch via masking but where is the binary for Monterey?
Can't seem to locate it.
@Shaneee,That would be great! The binary for Monterey is in /S/L/E —> IOPCIFamily.kext/Contents/MacOS
I’ll post the vanilla Monterey and Ventura binaries shortly (just woke up).
In Ventura, nearly all kext binaries are excluded from /S/L/E, but included in the KDK.
Seems that you uploaded IOACPIFamily instead of IOPCIFamily.@Shaneee,
Attached is the IOPCIFamily binary for Monterey. Ventura version coming shortly. Will update this post.
Hence the post about doing things after the morning coffee!...
@Shaneee / All,
I've updated the kernel patch post with an untested patch for Ventura. Will test the patch after coffee...
Also attached is the debug version of Ventura's IOPCIFamiliy binary. I created the patch based on this, hence the warning about it being untested should be taken seriously!
Alas, the KDK contains release and debug versions of the kernel, but only debug versions of kexts. I have already compiled Ventura's IOPCIFamily, but it's still possible that the binary differs from Apple's original.The binary kext will more than likely have it in a different location.
30:739 00:030 OCAK: 64-bit CaseySJ - fix probeBusGated 13.x replace count - 1
30:773 00:033 OC: Prelinked patcher result 18 for com.apple.iokit.IOPCIFamily (CaseySJ - fix probeBusGated 13.x) - Success
Hmm, wouldn't it have been a better idea to wait for more tests and for a single patch with masking?Zen 4 Patch · AMD-OSX/AMD_Vanilla@3120ca8
Zen 4 patch added for IOPCIFamily thanks to CaseySJ.github.com
@Shaneee,Alas, the KDK contains release and debug versions of the kernel, but only debug versions of kexts. I have already compiled Ventura's IOPCIFamily, but it's still possible that the binary differs from Apple's original.
I'll post my binary shortly (RELEASE mode).
Might want to do an announcement on the server then.It can always be updated. I'm sure there are people jumping to get it running can also get more testers this way.
@Shaneee,
If it helps, attached is my own compiled version of IOPCIFamily for Ventura. It's a "development" mode binary. The patch for this is:
Find: 83E02083 F8000F84 16010000
Replace: 83E02083 F8000F85 16010000
Will check momentarily if this works. UPDATE: Do not use this patch for Ventura. The previous one at least gets the system booted quickly.
This patch does not match the bytes in actual version of IOPCIFamily, so it doesn’t get applied.So this one doesn't boot? But previous one does? With the system working as expected?
