ethernet,Como você se conecta à internet? você usa wi-fi ou ethernet?
now I tried again and the mouse didn't work kkkkk I found it strangeEstranho, esse config.plist está configurado para isso, deve estar funcionando ......
I tried to use this config.plist that you sent me and gave this image errorExperimente este config.plist
Gave the same error as the imageReplace the config.plist in the efi folder with this one.
Se houvesse uma maneira de instalar o sistema offline no Boot PenDrive você não precisaria de internet, como faria isso?Preciso averiguar mais um pouco, já volto.
I t looks like you are using a recovery image for your installer which requires the internet. You made your installer pen drive under Windows, correct?Se houvesse uma maneira de instalar o sistema offline no Boot PenDrive você não precisaria de internet, como faria isso?
returned the same error screen as beforeReplaced the efi folder on your pendrive with this one and try to boot again.
This time a friend started a little differently and stopped just at the network card line again, I don't know if you did it on purpose, if it worked out I think, I'll send you the imagesLets try this efi, it will write a log file to the boot pendrive to help us find our problems.
