Problem with OpenCore Bootloader
POCTEXHAD3OP
35
Hello. There is a problem with OpenCore Bootloader. I do everything according to the instructions 'https://dortania.github.io/OpenCore-Install-Guide/AMD/zen.html', but MacOS doesn't start. When I select a MacOS disk in Bootloader, the computer restarts. I reworked bootloader several times, but nothing worked. I have this computer configuration.
CPU: AMD Ryzen 5 1400
GPU: MSI GeForce GTX 1050
RAM: 4Gb
HDD: 320Gb
Operation System: Windows 10 / MacOS 10.13.3 with Clover Bootloader
I want to update the system to 10.13.6. But this is not possible without OpenCore Bootloader
If someone has a similar computer configuration, could you share your EFI folder, or configure the bootloader for my system?
How did you come to that? OpenCore supports all versions of 10.13. Run your config through this website, https://opencore.slowgeek.com/
It'll show you any errors in your config. Seems like you are missing the kernel patches.
Share your full EFI and I'll take a look.
Try with this,
Reactions: POCTEXHAD3OP
You can try adding nv_disable=1 in your boot args.
Hello, I am currently writing with hackintosh 10.15.6. I repeated everything according to the instructions, and everything worked out
