- Joined
- May 31, 2020
- Messages
- 35
Hello. There is a problem with OpenCore Bootloader. I do everything according to the instructions 'https://dortania.github.io/OpenCore-Install-Guide/AMD/zen.html', but MacOS doesn't start. When I select a MacOS disk in Bootloader, the computer restarts. I reworked bootloader several times, but nothing worked. I have this computer configuration.
CPU: AMD Ryzen 5 1400
GPU: MSI GeForce GTX 1050
RAM: 4Gb
HDD: 320Gb
Operation System: Windows 10 / MacOS 10.13.3 with Clover Bootloader
I want to update the system to 10.13.6. But this is not possible without OpenCore Bootloader
If someone has a similar computer configuration, could you share your EFI folder, or configure the bootloader for my system?
RAM: 4Gb
HDD: 320Gb
