Need help with EFI: AMD Athlon X4 860K
baaaatt
AMD Athlon X4 860K
Hello everyone. I need help building a clean EFI for my Athlon X4 860k (Bulldozer 15h) with an MSI A68HM-E33 V2 motherboard and a GT 710 Kepler GPU.
I successfully installed Monterey using the UnPlugged offline script. The Recovery partition on my hard drive boots perfectly, but the main "Monterey" partition will not boot. It gets stuck in an endless loop with the error: com.apple.xdc.launchd, I can't reach the Welcome screen to set up the system.
My current EFI it's a mix of old forum patches that maybe are conflicting with my motherboard. I have tried checking all my Kexts (ACPI, USB, SATA, etc.) but the logd error never goes away.
Can someone help me fixing this efi? Thanks!
  • EFI (3).zip
    EFI (3).zip
