macOS v14 Sonoma and Boardcom BCM94360 problem
HKPhysicist
63
AMD Ryzen 5 5600H
You can still do a work around using Opencore Legacy Patcher to make the wifi card works. I updated to Sonoma also. At first my Fenvi wifi card didn't work. But after doing OCLP(Opencore Legacy Patcher) Patch everything's working.
However, you need to make changes to your config.plist before you can do the patching. You can check out what to change in the link below.
  • Love
Reactions: HKPhysicist
Thank you! Let me try! :D
Did you go through with this..? Any experience to share?
I read the linked post but for me — any solution that disables SIP or normal macOS behavior (like OTA updates) is not actual solution.
I have Kernel panics regarding IOSkywalkFamily being declared first (somehow duplicated I guess), but followed the patch guide to the letter ending on those unsuccessful attempts to boot only the installer.
I don't know what I am doing wrong!
Any help you could provide would be much appreciated!
Thanks in advance.
EDIT: no problem. I sorted out the panics by dragging the KEXTS into OCAuxiliaryTools window, but still not working my Fenvi T919
ADD: Succesfully working now. Although my WiFi card shares chipset with Fenvi T919, it has another PCI ID, so only thing I needed was to load AirPortBrcmNIC_Injector.kext plugin into my config.plist file.
Now it works either on Ventura(Natively), and on Sonoma (Injected).
Reactions: yurkins
