macOS Big Sur is on AMD
Aryann Gupta
Note: Installer does not yet run on Hackintoshes (both Intel and AMD), one has to install on a real Mac or VM and then transfer the installation. Latest nightly of OpenCore is ready for Big Sur now.
Also, it looks like Catalina 10.15.5 cannot read APFS format of Big Sur, you cannot restore the image to a single volume from Catalina.
how to transfer the installation from virtual box to my pc's ssd??? please help
I used a raw disk image, installing Big Sur directly to my SSD from VirtualBox (Note: the disk must be unmounted first)
Aryann Gupta
Hi Sir,
Can u please elaborate on the steps....how to basically install directly to the ssd??
also did u use VMware Fusion or virtual box???
Aryann Gupta
Could anyone please just explain how can I install directly install Big Sur to my ssd using virtual box???I have all of my efi ready for continuing but am unable to understand how to install directly on my ssd as only virtual hard drive is being shown in the disk utility page!!!
No support will be given. Anything that goes wrong is yours to fix,
For Windows:
VBoxManage internalcommands createrawvmdk -filename "C:\Users\<user_name>\VirtualBox VMs\<VM_folder_name>\<file_name>.vmdk" -rawdisk \\.\PhysicalDrive#
For Linux:
VBoxManage internalcommands createrawvmdk -filename "</path/to/file>.vmdk" -rawdisk /dev/sda
For Mac OS X:
VBoxManage internalcommands createrawvmdk -filename "</path/to/file>.vmdk" -rawdisk /dev/disk#
It was just announced that latest OC master should be able to handle KC and enforcing the prelinkedkernel is no longer necessary. There are some reports that the installer could at least be loaded natively now.
Great work by the developers of OC!
Installer does indeed work using latest commits of OC and the KC now. You need to use FakeSMC instead of VirtualSMC for the installer though.
@Phoenix In the German Hackintosh Forum.
MrParalyzed
Only 17h is supported? Guess I can't try out Big Sur for now.
rdymond
I tried to Install on Parallel Desktop
But It says
You cannot run a macOS virtual machine on your Mac.
Your Mac has the AMD main processor installed, while you can run macOS virtual machines on Intel-based computers only.
Please Guide.
As stated, this isn't supported by the community. Use Catalina.
Phoenix
Hi,
via MacBook Pro I got the Big Sur Beta 1 to run on my external Samsung 970 EVO Plus.
But as soon as I switch the external Samsung SSD to my Ryzentosh and try to boot Big Sur I get always this error message ( Attachment )
I mounted the EFI of 970 EVO Plus and copied my OpenCore EFI to it.
I have an AMD Ryzen CPU , an Asus Crosshair VI Hero MB and a Vega card.
Do you have an idea how to fix it?
slead
Hi,
In your config file, set the following:
Booter > Quirks:
RebuildAppleMemoryMap = False
If that does not work, then do the following too:
SetupVirtualMap = False
good luck
