GenMachine Ren5000
Use the ‘fix’ button on the Hackintool > power tab. This will set Hibernatemode and power nap to ‘0’. This is a start towards fixing your self/wake issues.
I performed these actions, there are no positive changes. Sleep mode does not turn off the fan.
Hi everyone, i am pretty new to this topic. I accidentally discovered this thread and really wanted to try this out. I have the same device at home. I searched this forum for some indepth guides, but could not find anything. Do you guys have so guides which could help me? I kind of have an brief idea what I have to do, but some more detailed instructions would be helpful.
Hello @Fahrenheiths, there are plenty of guides available online for how to create macOS USB Installation Media. From there the first page has a sample EFI folder that works with Sonoma 14.2, if you wanted to install a later version of Sonoma or Sequoia it would require updating OpenCore and the supporting kexts.
Updated to macOS Sequoia 15.4.0, had to build an installer USB, the 15GB + version and update that way. I think I have a hardware issue though, the KingSpec 128 NVMe is not always recognized and doesn't show up in BIOS, no activity LED either. CMOS battery?. Sonoma 14 does boot from the KingSpec 1TB SSD in the other slot though.
I have Gen Machine model AMD 5800H, please share EFI for Tahoe , Thank you
