Config.plist wrong?
Edwin
129
Netherlands
Ryzen 9 5900X
Hi guys, I accidentally replaced an old config.plist with my current one (I forgot to make a copy, how stupido I can be) and now Monterey won't boot. Any thoughts/help?
Hardware: Mobo Asus Prime X470 Pro, GPU AMD R9 390, CPU Ryzen 5 3600 6-core.
Greetings from the NL
DVD writer is currently connected to Sata port #4 but #3, #5 & #6 I also tried without succes. But again, it’s visible when I boot up Windows 11.
By the way, thanks Edhawk for diving into this matter👍🏼
OK, the images show there is nothing wrong with the SATA power or Data connections to the LG DVD writer.
You may just have a DVD writer that isn't compatible with macOS.
I have a couple of Blu-Ray devices which are the same, no matter what I tried they never worked or showed up in macOS. They worked as expected in Windows.
The DVD Writer in my main hack, running Big Sur 11.6.2, is enabled by /System/Library/Extensions/IOSCSIArchitectureModelFamily.kext/Contents/PlugIns/IOSCSIMultimediaCommandsDevice.kext
Is that plugin kext present in your system?
I’ll check it later. It’s close to 6pm here in the NL.
