I can have a look at the EFI later when I’m in front of my build. I didn’t expect you to get that far tbh, so I’m hopeful.Mac OS started to install, and after 12 minutes remained a memory panic occurred
thank you for thisI can have a look at the EFI later when I’m in front of my build. I didn’t expect you to get that far tbh, so I’m hopeful.
I generated bios for iMacPro 1,1One thing you should definitely try is adding the SMBIOS info for your laptop. We don't want to broadcast this info, so you should try it yourself. Noot suggests MacBookPro16,3 for laptops, that's entered in 'SystemProductName'. Corpnewts GenSMBIOS script will help with the rest of the info.View attachment 12902
GitHub - corpnewt/GenSMBIOS: Py script that uses acidanthera's macserial to generate SMBIOS and optionally saves them to a plist.
Py script that uses acidanthera's macserial to generate SMBIOS and optionally saves them to a plist. - corpnewt/GenSMBIOSgithub.com
Try using the MacBookPro16,3 SMBIOS.it no longer gives the memory panic error, now when you select the Mac OS installer, it only reboots, and I can’t enter the OpenCore EFI menu
