AMD ryzen 5 4600h?
electrowizard
17
Anyone with success on ryzem 5 4000 series laptops ?
I've MSI Bravo 15 with ryzen 5 4600h and Radeon 5500m GPU
GPU is supported...
It may only be the macOS version of the GPU that is supported but I suppose it couldn't hurt to try.
Reactions: electrowizard
Well I'm no phycic... Where is it stuck at?
20210207_194529.jpghere to be exact...
First it asks me to choose
1. Windows
2. Image Volume (external)
3. Reset NVRAM
And it stuck here for an hour or so after selecting Image Volume (external)...
Upload your current EFI folder. It doesn't say Image Volume either. Should mention the macOS Installer.
Well the config.plist is corrupt... I have no idea what version of OC that is but it seems old but try with this. If there are still errors I'll update it to the latest version.
First of all thanksssssss a lot for giving me your time.....
Second thing I'm trying to install bigSur and it says something like in second pic...
Using your efi...
That's easy to sort. Replace the config with this one.
It didn't worked 😭😭😭
Stucked here...
Is there any success with ryzen 5 4600h LAPTOP...
it's been months but didn't succeed...😭😭😭
But I won't give up...
Please be with me...
How did you make the USB? Try this,
I downloaded hackintosh shop big Sur image and made bootable USB using transmac...
For efi there are pre-made folders in downloaded image...
But none of them is working...
Should I switch?
Or modify and show the world that we can...
What version of opencore is this? I’ll update it to the latest version for you later. It may just be that the version of oc being used isn’t compatible with Big Sur.
Here is the same EFI but updated to OC 0.6.6
Still not working...
