Adobe Photoshop 2021 crashed in AMD hackintosh
Yeah...
Adobe softwares won't work out of the box.
See :
Also, my experience fixing those :
No luck. I identified the two dylib's that are causing the issue and tried to patch them. This resulted in a crash referring to the code signing being invalid. I then replace the two files from 2020 version and it fails to load.
any possiblities ?
@Shaneee I got an idea but I think it's an idiotic idea,,
In windows Adobe 2021 is supported for amd, so the that two dylib files can be patched through the windows's .DLL files,
I mean replacing the instructions.
Is it possible ?
I gone mad because Adobe 2021 has AI interface so only I started to think mad
@Jesinth From what Shaneee wrote the problem is not which instructions to replace, but that the files are cryptographically signed by Adobe to prevent any modifications.
@rushpracticesalmon Yes latest 2021 version.
@Jesinth The files are signed by Adobe and any modification will stop the application from loading.
Exception Type:        EXC_CRASH (Code Signature Invalid)
Termination Reason:    Namespace CODESIGNING, Code 0x2
  • Sad
Reactions: ThibautFlt
So, does it mean that there wont be a fix ? :o
@Shaneee I found a fix for photoshop 2021 in this website " "
the fix :::
Fix for Photoshop 2021, just change the first command like this:
________________________________________________________________________________________________________________________________________________________________
for file in MMXCore FastCore TextModel libiomp5.dylib libtbb.dylib libtbbmalloc.dylib; do
find /Applications/Adobe* -type f -name $file | while read -r FILE; do
sudo -v
echo "found $FILE"
[[ ! -f ${FILE}.back ]] && sudo cp -f $FILE ${FILE}.back || sudo cp -f ${FILE}.back $FILE
echo $FILE | grep libiomp5 >/dev/null
if [[ $? == 0 ]]; then
dir=$(dirname "$FILE")
[[ ! -f ${HOME}/libiomp5.dylib ]] && cd $HOME && curl -sO https://excellmedia.dl.sourceforge.net/project/badgui2/libs/mac64/libiomp5.dylib
echo -n "replacing " && sudo cp -vf ${HOME}/libiomp5.dylib $dir && echo
rm -f ${HOME}/libiomp5.dylib
continue
fi
echo $FILE | grep TextModel >/dev/null
[[ $? == 0 ]] && echo "emptying $FILE" && sudo echo -n >$FILE && continue
echo "patching $FILE \n"
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' $FILE
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' $FILE
done
done
the photoshop is now opening and I am able to use it
But biggest problem is "liquify", "Adaptive wide angle", "Neural filter" (these are in filter bar) and even "object selection tool" is not working(it crashes)
Reactions: RyzeCooker
They always keep changing these things... I'll probably just sell the amd hardware and go intel just for the Adobe stuff.
Reactions: Jesinth
You could still use KVM to run Adobe without issues.
or use a previous working version..till a fix will be found :)
Reactions: rajovo
You can run Adobe without any troubles going the virtualization route.
