Adobe Photoshop 2021 crashed in AMD hackintosh
rushpracticesalmon
Yeah...
Adobe softwares won't work out of the box.
See :
Also, my experience fixing those :
No luck. I identified the two dylib's that are causing the issue and tried to patch them. This resulted in a crash referring to the code signing being invalid. I then replace the two files from 2020 version and it fails to load.
Jesinth
any possiblities ?
Jesinth
@Shaneee I got an idea but I think it's an idiotic idea,,
In windows Adobe 2021 is supported for amd, so the that two dylib files can be patched through the windows's .DLL files,
I mean replacing the instructions.
Is it possible ?
I gone mad because Adobe 2021 has AI interface so only I started to think mad
@Jesinth From what Shaneee wrote the problem is not which instructions to replace, but that the files are cryptographically signed by Adobe to prevent any modifications.
@rushpracticesalmon Yes latest 2021 version.
@Jesinth The files are signed by Adobe and any modification will stop the application from loading.
Exception Type:        EXC_CRASH (Code Signature Invalid)
Termination Reason:    Namespace CODESIGNING, Code 0x2
ThibautFlt
So, does it mean that there wont be a fix ? :eek:
Jesinth
@Shaneee I found a fix for photoshop 2021 in this website " "
the fix :::
Fix for Photoshop 2021, just change the first command like this:
________________________________________________________________________________________________________________________________________________________________
for file in MMXCore FastCore TextModel libiomp5.dylib libtbb.dylib libtbbmalloc.dylib; do
find /Applications/Adobe* -type f -name $file | while read -r FILE; do
sudo -v
echo "found $FILE"
[[ ! -f ${FILE}.back ]] && sudo cp -f $FILE ${FILE}.back || sudo cp -f ${FILE}.back $FILE
echo $FILE | grep libiomp5 >/dev/null
if [[ $? == 0 ]]; then
dir=$(dirname "$FILE")
[[ ! -f ${HOME}/libiomp5.dylib ]] && cd $HOME && curl -sO https://excellmedia.dl.sourceforge.net/project/badgui2/libs/mac64/libiomp5.dylib
echo -n "replacing " && sudo cp -vf ${HOME}/libiomp5.dylib $dir && echo
rm -f ${HOME}/libiomp5.dylib
continue
fi
echo $FILE | grep TextModel >/dev/null
[[ $? == 0 ]] && echo "emptying $FILE" && sudo echo -n >$FILE && continue
echo "patching $FILE \n"
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' $FILE
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' $FILE
done
done
the photoshop is now opening and I am able to use it
But biggest problem is "liquify", "Adaptive wide angle", "Neural filter" (these are in filter bar) and even "object selection tool" is not working(it crashes)
rajovo
They always keep changing these things... I'll probably just sell the amd hardware and go intel just for the Adobe stuff.
Jesinth
But i bought my pc a month ago so how can I sell it 😭😭😭
Pls help 😭😭😭
You could still use KVM to run Adobe without issues.
Deleted member 473
or use a previous working version..till a fix will be found :)
olbo
You can run Adobe without any troubles going the virtualization route.
