Can't install tahoe, hope someone can help
tr4c3r2k12
11
Ryzen 7 9700x
hi, its been a while since my last post on this site, hope everybody is doing well, this is my problem, i have been using hackintosh since 10.4 to 15, everything went well, since january, i change to Linux, now im trying to install tahoe on another disk, i want to keep my Linux install, im trying to boot from the usb but it hangs, i dont know what could be the problem, this is my hardware MSI X870 Tomahawk WIFI - AMD Ryzen 7 9700x - DDR5 64 Gb 6000 Mhz G.SKILL Trident Z5 (32 Gb x 2) - 2 TB Kingston NV2, 256 Gb Kioxia MacOs - ASRock Radeon rx 6600 8 Gb, i have a Realtek RTL8126, use @laobamac_yyds SIMPLEAERL v1.1 kernel patches, but i dont know whats happening, i dont know if it could be related to usb mapping, is there a way to map USB ports in Linux?, and also, i dont know if i have all the SSDTs i need, ryzen is still kind of new to me i have always used intel, if someone could give me hand i really apreciated
    EFI.zip
If anything, you have too many SSDTs: Keep only one of -CPUR and -PLUG-ALT, they serve the same function.
You alse have many disabled entries, which does not help reading the config.plist. And yet your DSDT may need some more patches to enable devices (see which ones, or post your ACPI tables).
Have you booted Sequoia, or earlier, on this system? Tahoe is more complicated, and installation may require trimming down the EFI (no unecessary kexts such as the AMD management ones).
Kernel panic has AppleRTL in backtrace, so I'd suggest to disable SimpleRTL patches and try with RTL812xLucy.kext instead.
Reactions: Edhawk
Good tips from @etorix . Attached is an EFI I was using with an MSI X870E Carbon Wifi board attempting to use SimpleBCM.kext. You should probably note the kext section of the EFI contains multiple kexts that are not enabled including USB Port mapping kexts. Its very likely you can boot Tahoe without USB Port mapping, you'd need to find one of the ports that gets activated by Tahoe to be able to finish the install. If the prohibited sign shows its face try another port. Once you complete the install you can use Hackintool or CorpNewts USBMaster to zone in on identifying an accurate port map.
I don't have @laobamac_yyds SIMPLEAERL solution for the realtek RTL8126 but you can add it in. Maybe this will help get you off the ground.
In case it’s not immediately obvious you will need to adjust your CPU core counts.
Reactions: etorix and Edhawk
Extremely likely, though can't confirm with the OPs hardware, and not to suggest you shouldn't.
The Verbose text image provided by the OP shows an issue with the Ethernet setup. So going with a standard Realtek Ethernet kext would be recommended.
Reactions: leesurone
hi @etorix i used to have sequoia in this machine, i havent change anything, i did upgrade the bios to version 1.A93, the SSDTs, CPUR and PLUG-ALT, both are on the folder but only CPUR is enabled, with PLUG-ALT the machine freezes, i attach the acpi tables from SSDTtime, thanks for your reply
thanks @leesurone i will try it, and let you know what happends
i try without laobamac_yyds patches, and no kexts for network or wifi, the first efi y made only had lilu, virtualsmc and whatevergreen, restrictevents, and usbmap, cuald it be related to the usb ports not properly mapped, id there a way to map port on linux or is only for windows an mac? thanks for your reply @Edhawk, also what options in Bios should be enabled or disabled, i think i have them rigth but maybe i missed something.
Hi everyone, i did some changes in config.plist, i think is now is booting, but need to remap my USB, what do you use to map your USB, corpnewt/USBMap?, or what tool do you recomend to map usb to make then tahoe compatible, i believe i read somewhere that usb from sequoia to tahoe change, thanks for you help, im closer to make the installer and the config.plist usuable
Use Corpnewt's USBMap script to create the Tahoe compatible USB kext.
You are correct, Apple made some changes to the USB port naming and numbering conventions when Tahoe was released. So some additional entries are required in the kext to make it work with Tahoe, compared to Sequoia or and earlier version of macOS.
When discovering and configuring the USB ports in USBMap use these points to guide you.
USB2 (0) - Physical USB2 ports on rear I/O plate, these ports always have a Black coloured tang. These are the only ports that should be set as USB2 (O).
USB3 (3) - Physical USB3 ports on rear I/O plate, these Type-A ports can have a Red, Blue, Yellow or Cyan coloured tang.
Virtual USB2 ports - served from physical USB3 ports should be set the same as the physical port
USB3 (3) - Motherboard Header, usually serving the case front Type-A USB3 ports.
Internal (255) - Motherboard USB2 header, this will be any device served from a header port, such as Bluetooth module, case front USB2 ports, case front card reader etc.
Internal (255) - Built-in M.2 WiFi/BT connector, motherboard LEDs and CPU Cooler USB connection.
Type-c+sw (9) - will only show two ports being available, 1 x Physical Type-C and 1 x virtual USB2 port.
Type-c (10) - will show 4 x ports being available.
This occurs when the Type-C device initially inserted, then removed with the device flipped 180° and reinserted in the same port, 2 x Type-C and 2 x virtual USB2 ports.
Reactions: etorix
Thanks for this piece for my little collection.
As I expected, it fits the pattern for the _msi set of patches.
Hi, still trying to install tahoe, i map my usb i dont know if i did it rigth, and make some changes to config.plist, now sometimes it boots, sometimes i think it boots but give me a black screen, and when i try to enable laobamac_yyds patches to have rtl8126, givs me a kernel panic, i map my usb using usbmaptool from a windows usb, what do you guys think its the problem? thanks, i really hope you can give me some guidance
    EFI.zip
You asked if your USB Port mapping is correct, it might be if you were using Sequoia however the format kext that USBToolBox creates is not compatible with Tahoe. There are a couple of solutions for that, if you are able to boot into Tahoe follow the suggestions EdHawk made above and use USBMap Master by CorpNewt.
If not then using USBToolBox go into options, hit "C" and change the kext output to "Native Classes" which will create a stand alone USBMap.kext instead.
That kext can be edited to become Tahoe compliant using USBMap Master's USBMapInjectorEdit.command in macOS, I beleive that can also be done in Windows if there is also a *.bat file
Hi everyone, i found and old 256gb m2 disk with tahoe installed, i put it in my pc and boot from there, map the usb with corpnewt usbmap tool, and did the mapping there, is the resulting usbmap.kext compatible with tahoe?, i map some usb hub as internal, i believe i read it on someones post, i attach an image on how the usb map turned out, i can boot to sequoia, but still having some trouble with tahoe usb installer, have SSDT-CPUR, SSDT-EC, SSDT-USBX, enabled sometimes boots, sometimes gives me kernel panic, do i need more or those 3 are just fine.
In your config.plist under the Kernel/ Emulate section you need to enable "DummyPowerManagement". Without that your system will be unstable and eventually crash. Try changing that and see if it helps.
As far as your USB mapping goes it looks close. I'd review EdHawks guidelines on internal hubs as some should be configured as type 3 and some as 255, internal. If your kext is built properly your system should sleep for a period of time and then wake to normal use. If it crashes or the screen stays dark it typically means something is incorrect.
