Part 1 is not there just for convenience. It provides links to versions of the VMware software that work with the macOS VM creation process.
You can update the VMware application after getting your macOS VM up and running.
I gave it a try, and I was able to update from Tahoe 26.3 to 26.6.
I followed the same procedure as for Tahoe 26.3. After booting up, I ran:
softwareupdate --fetch-full-installer --full-installer-version 26.6
in Terminal.
Once the download completed successfully, I launched the installer and followed the on-screen instructions. When the VM rebooted into OpenCore, I selected the macOS Installer entry and let the installation proceed.
The installer initially showed com.apple.BuildInfo.preflight.error 21, but after rebooting and selecting my usual macOS disk, the update had completed successfully.
The system is now running Tahoe 26.6, and so far everything is working fine.
Thank you.
AMD Ryzen 7 2700x 8core/GTX 1070
Reactions: Froslass
I would say not on an AMD system. But I could be wrong.
i keep getting this. Ive been trying for 2 days now and nothing seems to work, ive uninstalled and reinstalled, cleared all the files etc and still nothing. gonna give up soon! (AMD ryzen 7 7800 AM5)
*** First of all, don't make any changes to the vmware .vmx file. It is recommended that you create a new virtual machine from scratch so that it recreates this file by default and without any changes.
*** Use VMWare Workstation Pro version at the link provided in the tutorial. (If you install it, you will have to make a new Patch as described)
*** Enable AMD-V or INTEL VT (Virtualization Technology) in BIOS. (you should research how to do this on your machine)
1) First you need to download VMWare Workstation Pro:
- VM Workstation Pro 17.6.3: (NOW IS FREE FOR ALL USERS)
- Download Unlocker to patch VMWare:
- After installing VMWare close it.
Extract all the unlocker files into a folder, open the command prompt (terminal) in administrator mode and run "win-install.cmd".
This patch releases the Apple Mac OS X version configuration option in VMWare under Virtual Machine Settings, Options, Apple Mac OS X:
use "macOS 15" when configuring your virtual machine:
2) Also download an ISO of macOS:
Sonoma 14.7.6
Link1: https://mega.nz/file/tAkzQA5B#XJeNhYN4xKatkmObgRvbrZy0TD7vQi6-KJvKQ_SYOGk
Sequoia 15.2 ISO
Link1: https://data.pyenb.network/macOS/isos/torrents/macOS Sequoia 15.2_24C101.iso.torrent (Use Torrent app to download with this file)
macOS Sequoia 15.5 ISO (try a link that works better or you can download it)
Link1: https://hackintosh-images.ddns.net:10443/macos/Sequoia_15.5.torrent.zip (Unpack and use Torrent app to download with this file .torrent)
Link2: http://hackintosh-images.ddns.net:8090/macos/Sequoia_15.5.zip
Link3: https://mega.nz/file/pQ90jYqD#xauoqi4qGQTvRacRJ7i_xKXhnyR5WY6bvzC_byOcYTg
macOS Tahoe Beta
https://forum.amd-osx.com/threads/m...works-with-sequoia-sonoma-etc.4696/post-41807
Sequoia is working with Apple's login services (iServices). WMHide.kext and Lilu.kext 1.7.0 have been incorporated into the VMDK image Opencore updates.
Tahoe is working with Apple's login services (iServices) using iCloud Pacth. (AMD only for while)
3) Download a small VMWare disk image file:
INTEL PROCESSORS ONLY
This version only works with INTEL processors with any numbers of cores avaliable in your machine (test to better performance):
Download New Version of VMWare disk image file Here: OPENCORE 1.0.4
https://mega.nz/file/YY9zSZ4C#PtilBDmBZV8DRhkGaA7xQBkjvllmGg8OyIp321MJ7Vk (FOR INTEL MACHINES)
This file contains Opencore 1.0.4 on an EFI partition and should be chosen as a disk image on the SATA 0:0 drive in the VMWare settings. It should always be used that way.
AMD PROCESSORS ONLY
This version only works with Ryzen processors with 4 cores or more
Download New Version of VMWare disk image file Here: OPENCORE 1.0.4 - 4 cores
https://mega.nz/file/hQkUBKQY#2PeSE3cO4DFin5FLwcvEiEZqivyzALirTGUpR6lcNbU (FOR AMD MACHINES)
OR DOWNLOAD:
This version only works with Ryzen processors with 8 cores or more
Download New Version of VMWare disk image file Here: OPENCORE 1.0.4 - 8 cores
https://mega.nz/file/AAsWGZqT#1o-0zbqc3imAQBv11C88pe-r3KuDRevEs_vZs06dyvo (FOR AMD MACHINES)
OR DOWNLOAD:
This version only works with Ryzen processors with 16 cores or more
Download New Version of VMWare disk image file Here: OPENCORE 1.0.4 - 16 cores
https://mega.nz/file/tVM03LQQ#uoG5oBeOhsTN8cyJwO7jR8g701ZIkzGbxuPA-LhpsMY (FOR AMD MACHINES)
OR DOWNLOAD
macOS Tahoe (iso version 26.3):
VMWare settings FOR AMD/INTEL:
a) Memory:
8GB (recommended 50% of your host machine)
b) Processors:
Intel: Usually 50% of your machine's Intel processor cores.
AMD 4 cores (if you are using the VMWare disk image file with 4 cores)
AMD 8 cores (if you are using the VMWare disk image file with 8 cores)
AMD 16 cores (if you are using the VMWare disk image file with 16 cores)
c) Hard Disk (Sata):
macOS_Opencore_1.0.4_4_cores.vmdk or
macOS_Opencore_1.0.4_8_cores.vmdk or
macOS_Opencore_1.0.4_16_cores.vmdk or
macOS_Opencore_1.0.4_intel_.vmdk
in (SATA 0:0) Should always be the first boot drive.
In newer versions of WMWare choose "Keep existing format" if you are asked when adding the image of this drive.
4) Hard Disk 2 (Sata): This drive is where macOS will be installed. Any size you see fit.
5) CD/DVD (SATA): Use ISO image file (Ex. Sonoma.iso, Sequoia.iso, etc.)
6) USB Controller 3.1.
7) Network Adapter: Bridged Automatic.
Installing macOS​
It is recommended that you read and make the changes mentioned in Item 8 of this tutorial before starting the installation.
When you start the virtual machine to install macOS, choose the CD/DVD drive that was attached by the ISO file in the VMWare settings labeled "Install macOS Sequoia" or "Install macOS Sonoma".
After, during installation, only erase or format the macOS installation drive you created using Disk Utility. Never do this on the OPENCORE drive (it must remain untouched):
ATTENTION !!!!!!!​
8) (IT GREATLY IMPROVES PERFORMANCE AND CORRECTS ERRORS :)
Before Installation:
In order to correct the “errors” during start-up, which in spite of everything works.... and also to correct the performance and reduce the “slowness” of the virtual machine, you should turn off the windows hypervisor. To do this, use the tip below:
- In Windows, click on Start and search for Command Prompt.
Right-click Command Prompt and then click Run as administrator.
If the User Account Control dialog box appears, confirm that the action shown is the one you want and click Continue.
Then type:
bcdedit /set hypervisorlaunchtype off
(and Hit enter)
Then type:
reg add "HKLM\SYSTEM\CurrentControlSet\Control\DeviceGuard\Scenarios\HypervisorEnforcedCodeIntegrity” /v “Enabled” /t REG_DWORD /d 0 /f
Press enter again.
Restart the computer.
- It is also recommended to disable the "Memory Integrity Checks" in Windows to improve performance.
After Installation:
- Install VMWare Tools to change the resolution. It comes with VMWare Workstation, I don't remember if VMWare Play has VMWare Tools.
- You can only change the resolution within MacOS. Ex: 1600x1100. To do this, type in the terminal :
sudo /Library/Application\ Support/VMware\ Tools/vmware-resolutionSet 1600 1100
Note: In VMWare's Display settings you need to set the resolutions higher than or equal to the ones you'll be using in macOS.
Issues:
Crash, Stopped during installation or Repetitive errors when loading the system
It was probably discovered that windows hypervisor hinders the normal functioning of VMware. You should turn it off. It can be done at the end of everything even after macOS is fully installed. See item 8.
White background (wallpaper)
***** When I first got macOS, I had this problem with a white background (wallpaper) in the system background. But you have to go into the macOS settings and click on Wallpaper and then deactivate the Show as screen saver option. Then choose a wallpaper you like.
SLOW UPLOAD SPEED
A problem with file upload over the network has been reported in some specific access cases that makes the network very slow when sending a file.
This happens due to a problem with the vmware vmxnet3 network driver.
I tested this solution and managed to solve this problem.
Open the Mac terminal and type the commands below in sequence:
sudo sysctl -a | grep net.inet.tcp.tso
sudo sysctl -w net.inet.tcp.tso=0
sudo nano /etc/sysctl.conf
Add the below entry in the sysctl.conf file
net.inet.tcp.tso=0
Press Control + O to save and then Enter to save. Control + X to exit.
Restart macOS.
I have followed these steps over and over and all i get is that the virtual machine failed to start, im on day 2 now :(
Hello, i successfully got sequoia up and running, but i wanted to update to macOS26 since that's required to test apps on my iphone with ios 27. I was wondering if i could use macOS_Opencore_1.0.4_16_cores.vmdk for that vm, or if i'm stuck with 8 cores using macOS_Opencore_Tahoe_1.0.5_8_cores.zip. Has anybody tried running it with 16 cores?
For anyone who can't login after installing (password isn't working and you know it is correct) - make sure you DO NOT enable FileVault and do not sign in to iCloud during setup as it automatically enables FileVault.
For anyone having this error: if you signed in with icloud during installation (like i did) filevault is automatically enabled. You can disable it without reinstalling the vm following those steps:
1) restart in recovery mode (hold windows+r while the machine is booting)
2) open Utilities->Terminal
3) write "diskutil apfs list" and see which one in the list has "FileVault: Yes", in my case it was disk4s1
4) write "diskutil apfs unlockVolume /dev/<paste identifier>", in my case "diskutil apfs unlockVolume /dev/disk4s1"
5) write "diskutil apfs listcryptousers /dev/<paste identifier>", in my case "diskutil apfs listcryptousers /dev/disk4s1"
it will show the uuid associated to the accounts e.g. "89AFEF76-68BF-4965-B5D8-D179F7D3E19D" (i had 2 of them and i just tried them both)
6) write "diskutil apfs decryptVolume /dev/<paste identifier> -user <paste uuid>", in my case "diskutil apfs decryptVolume /dev/disk4s1 -user 89AFEF76-68BF-4965-B5D8-D179F7D3E19D" and press enter, it will ask for your password (the one to login inside the mac, not your apple account password)
7) it will start decrypting the volume, if you want to see the status just write "diskutil apfs list", it will show "Decryption Progress: 37%" if it's still decrypting or "FileVault: No", if it finished
8) just reboot the machine and now you can login
you are using 2 cores, the only available numbers of core are 4, 8 and 16... your hard disks are also both 80gb, one should be about 2gb, you are clearing not following the guide correctly, try following this one, might be clearer https://github.com/ZenDeuo/MacOS-VM...setup--configuration--installing-vmware-tools
