It looks like the system update is not seeing the 15.7.1 update and I have to trigger it from the App store.
That's true, but I haven't done any specific work to find out why. If anyone knows, please let us know.
For now, you need to download and run the update from the Apple Store or using gibmacos tool.
Hi, could you tell me how you applied the iCloud patches? When I turn on vmhide and start MacOS, it seems to stay on the logo interface and become unresponsive. After turning off vmhide, the apple service is no longer available.
Yes, I tested the latest version of vmhide.kext, and it crashes macOS Tahoe startup. With the patch, the problem is solved and ensures that Apple Services such as iCloud and Apple Store work.
I even did a quick test, and it also works with Sequoia. But you have to disable vmhide.kext startup, and if you want, you can also remove it.
In the same place where you add the patch to work with AMD processors (Kernel/Patch), you add these two new lines. There are two iCloud patches, one on each line.
You will find this patch already applied in this location if you open opencore 1.05, which I posted at this link:
https://forum.amd-osx.com/threads/m...with-tahoe-sequoia-sonoma-etc.4696/post-41807
<dict>
<key>Arch</key>
<string>x86_64</string>
<key>Base</key>
<string></string>
<key>Comment</key>
<string>iCloud Patch Part 1</string>
<key>Count</key>
<integer>1</integer>
<key>Enabled</key>
<true/>
<key>Find</key>
<data>aGliZXJuYXRlaGlkcmVhZHkAaGliZXJuYXRlY291bnQA</data>
<key>Identifier</key>
<string>kernel</string>
<key>Limit</key>
<integer>0</integer>
<key>Mask</key>
<data></data>
<key>MaxKernel</key>
<string></string>
<key>MinKernel</key>
<string></string>
<key>Replace</key>
<data>aGliZXJuYXRlaGlkcmVhZHkAaHZfdm1tX3ByZXNlbnQA</data>
<key>ReplaceMask</key>
<data></data>
<key>Skip</key>
</dict>
<dict>
<key>Arch</key>
<key>Base</key>
<string></string>
<key>Comment</key>
<string>iCloud Patch Part 2</string>
<key>Count</key>
<key>Enabled</key>
<true/>
<key>Find</key>
<data>Ym9vdCBzZXNzaW9uIFVVSUQAaHZfdm1tX3ByZXNlbnQA</data>
<key>Limit</key>
<key>Mask</key>
<data></data>
<string></string>
<string></string>
<key>Replace</key>
<data>Ym9vdCBzZXNzaW9uIFVVSUQAaGliZXJuYXRlY291bnQA</data>
<data></data>
<key>Skip</key>
</dict>
Reactions: sashagg
I can't seem to update to 15.7.1. It will download but fail upon installation.
How do I download the update as an ISO that I can mount and install?
edit: downloaded it from here: https://mrmacintosh.com/macos-sequoia-full-installer-database-download-directly-from-apple/
Here's how to create the macOS Sequoia ISO file on macOS.
Install the InstallAssistant.pkg file you downloaded from the internet and follow the steps below:
Open Terminal via Spotlight or by clicking Finder > Applications > Utilities > Terminal.
Copy and paste the following command into Terminal and press Return to create an empty disk image.
hdiutil create -o /tmp/Sequoia -size 17810m -volname Sequoia -layout SPUD -fs HFS+J
The size of the disk image (17810m) should be adequate for the macOS installer; this value may vary depending on the actual size needed.
Mount the disk image you created using the following command:
hdiutil attach /tmp/Sequoia.dmg -noverify -mountpoint /Volumes/Sequoia
Create the installation media by running the command below. Enter your administrator password when prompted.
sudo /Applications/Install\ macOS\ Sequoia.app/Contents/Resources/createinstallmedia --volume /Volumes/Sequoia --nointeraction
Ensure that the name of the macOS installer app (e.g., “Install macOS Sequoia.app”) is correct and matches what you have in your Applications folder.
Eject the disk image once you see the message "Install media now available at "/Volumes/Install macOS Sequoia".
hdiutil eject -force "/Volumes/Install macOS Sequoia"
Continue to run the command to convert the disk image to a CRD file.
hdiutil convert /tmp/Sequoia.dmg -format UDTO -o ~/Desktop/Sequoia
Execute the command below to rename the CDR file to an ISO file.
mv -v ~/Desktop/Sequoia.cdr ~/Desktop/Sequoia.iso
Delete the temporary disk image file with the following command:
rm -fv /tmp/Sequoia.dmg
The ISO image will be on the MacOS desktop, and if you want, you can use a USB flash drive or the network to transfer the file to your Windows host.
Reactions: tangcla
I just double-clicked the pkg file, and then ran "Install macOS Sequoia" in the Applications.
Once installed, will I free up space by removing the application?
Yes, you have installed the macOS update installer. If you want, you can remove the InstallAssistant.pkg that was used, but Install macOS Sequoia.app will be installed in your list of macOS applications and can be used both to update your Mac and to create the ISO file.
Only after performing one of the above options can you then also remove Install macOS Sequoia from the list of applications.
Reactions: tangcla
Does it really take up 14.54GB?
Yes, if you create the ISO for the newest version of Sequoia, it is over 17 GB, and those for Tahoe are over 18 GB.
If you try to create a smaller size, such as 14GB, in Sequoia:
hdiutil create -o /tmp/Sequoia -size 14000m -volname Sequoia -layout SPUD -fs HFS+J
The file will be created, but when you try to use the command in the terminal:
A message will appear telling you how much space is needed to create the dmg file in the image file that was mounted. This warning allows you to calculate how much you really need by simply adding to the value of 14.0 previously created.
Then you need to unmount the mounted drive and delete the dmg file with the command below to recreate it with the correct size:
hdiutil eject -force "Sequoia"
After that, restart the entire process to create the ISO.
Dear Tucano,
Thanks so much for your hard work and the VMWare disk Image File Tahoe Version
I got 26.01 running.
To get the sound working I had to use a usb sound dongle.
tplink ub400 works on Sequoia with updated kexts, but not here.
Reactions: tucano2000
Dear Tucano,
Very good. I'm glad to see that you managed to do it with Tahoe 26.01 (the non-beta version). I'll be posting the ISO for this version soon.
Dear Tucano,
Could you please help me look into my problem? Thanks
Is Tahoe performance still slow? Or is it much better out of beta?
Someone already discovered how to fix this? It has been stuck for a pretty long time. I don't know if I have to wait or do anything else… Done every step of item 8.
Hi. what heppend with apple. I unable to login in apple store in sonoma, tahoe, ventura? Even cant create new accaunt.
I was referring to the link to download the VMware patch tool to unlock, which was previously not working and has now been fixed and which is also done by running win-install.cmd in the Windows command prompt as an administrator.
Another member of the channel commented about broken link and I referred to their post because I thought they were having trouble downloading and using a different method that doesn't even require Python to be installed.
Great job... Finally working... Kudos 😎
Hello.
I installed MacOS Sequoia 15.2 on VMware from this thread. Everything installed perfectly. It works. I used OCAuxiliaryTools to change the device information. I successfully logged into my Apple ID.
Do you think I can update to MacOS 26.0 right away? I wanted to install Xcode and the iPhone simulator.
Sorry, I'm from Russia. Here's a screenshot of the system for the Russian region. Thank you.
Thanks! I was able to install Monterey using VMware!!!! Yayyyy!
Hello Sir! Thanks so much for this! Any luck with the 26.01 ISO?
For anyone who can't login after installing (password isn't working and you know it is correct) - make sure you DO NOT enable FileVault and do not sign in to iCloud during setup as it automatically enables FileVault.
