Error Desktop - Ryzen 7 5700g - PCH-B550 - 16GB
renegadofp
13
Ryzen 7 5700g
Hi, sorry for my English—I'm using Google Translate—but I was wondering if anyone could help me. I've been trying to perform the installation for nearly 20 days now and ran into several issues, some of which I managed to fix along the way. After resolving problems like the OpenCore boot stalling at EXITBUS:START, I got stuck on a kernel panic that I can't seem to get past. I created the EFI using OpenCore Simplify and tried a few pre-configured ones, but eventually, I took a base configuration from https://github.com/mikigal/ryzen-hackintosh and customized it for my specific setup.
    config.plist
Points for you to look into.
  1. You have some unnecessary and duplicate SSDT’s in your /EFI/OC/ACPI folder and config.plist.
    1. You don’t need SSDT-USBW.aml with your B550 system. I would remove this ACPI table.
    2. SSDT-XOSI.aml won’t work if the accompanying ACPI Patch isn’t available in your config.plist. Either add the ACPI Patch or remove the SSDT.
    3. When using SSDT-EC-USBX-DESKTOP.aml table you don’t need a separate SSDT-USBX.aml table as well. Remove the separate SSDT-USBX table.
  2. You need to remove WhateverGreen.kext from your /EFI/OC/Kexts folder and config.plist, as you don’t need it when using NootedRed.kext with an AMD IGPU/APU.
    1. The two kexts clash when both are present and enabled in the config.plist.
  3. Also SecureBootModel should be set to ‘Disabled’ not left as ‘Default’.
See if making these changes help.
Reactions: renegadofp
Thanks for the reply. I removed the USBW, XOSI, and USBX SSDTs, removed the WhateverGreen kext, and set SecureBootModel to disabled. However, I believe the same error persists; here is a screenshot—only a few numbers have changed. And just in case it helps, here is the EFI folder.
  • EFI.rar
    EFI.rar
If you need any more help it would be best if you posted (zipped and attached) a copy of your EFI folder, as the config.plist doesn't always tell us the whole story.
I have a couple of B550/B550M Hacks so providing details of the components (make & model) in your system would also be helpful. I also have a Mini ASRock Hack that uses the Ryzen 7 5700G CPU/APU.
Does your B550 motherboard contain a 1G or 2.5G Ethernet port? The kext in your OC folder is for a 1G Realtek Ethernet port, I ask because both of mine have a 2.5G Ethernet ports. The 2.5G Ethernet port requires a different kext compared to the 1G Realtek ethernet port.
Have you set the bios to allow macOS to run, including setting Above 4G Decoding to Enabled? Again I ask as it is possible you need to add 'npci=0x3000' boot argument to your config.plist, if Above 4G Decoding is disabled in your Bios.
Try this slightly revised EFI folder, see if this helps.
The network card is 1Gb, and regarding the EFI folder—I believe it hung while handing off to the macOS kernel; it stayed on that screen for about 10 minutes. I enabled logging to generate a file for easier review, and I've attached it here as well.
And thank you very much for the help.
One thing I noticed is that SetupVirtualMap wasn't enabled in your EFI; when I tried enabling it, I ran into the same kernel panic mentioned in the first post.
Are the screenshot and OC log in post #7 from when you booted with my revised EFI or after you changed the SetupVirtualMap quirk?
I don't have the SetupVirtualMap Quirk enabled on either of my B550 hacks. If you read the OpenCore Ryzen guide, it recommends that B550 systems should set this quirk to Disabled/False.
Which Drive are you using for the macOS installation in your B550 system, make and model of the drive might shed some light on the issues you are facing.
Do you have any other drives connected in your B550 system. If yes, try booting with the revised EFI when these other drives have been disconnected or removed from the system. You should only have the proposed macOS drive and the USB installation drive connected when installing macOS. This helps to avoid unnecessary issues and is just temporary while macOS is being installed. They can be reconnected/installed once macOS is up and running.
Check you have your bios set correctly to run macOS. See this link to the bottom of the Dortania OpenCore Ryzen guide.
when I started using your EFI.
I didn't quite understand; is the drive you're referring to the SSD?
If you're referring to SSDs or NVMe drives, yes, I have three or more connected. If you mean USB peripherals, I have a mouse, keyboard, headset, and speakers.
The BIOS configuration is correct.
I’m going to disconnect everything and leave only the SSD intended for the Mac—along with the USB drive—to try using your EFI, and I’ll also remove any other connected USB peripherals. Thanks.
Yes, what is the make and model of your SSD?
You obviously don’t want to disconnect the mouse and keyboard when disconnecting the other USB peripherals.
The empty drive is the ADATA SU650, and no, I won't be disconnecting the mouse and keyboard.
I also have two other SSDs: a Western Digital (WDBNCE2500PNC) with Windows and a SanDisk (S3SSDC240) with Linux.
Ok, none of them are specifically mentioned on the anti Hackintosh buyers guide.
The ADATA drive is a fairly low level drive and not something I would recommend as the macOS drive in a Hack.
Got it. So, would one of those three—WD or SanDisk—be the best option? I can switch systems without an issue if necessary... my worry is reinstalling everything and it still not working... I'll give it a try soon with your latest specifications and let you know the result.
I removed all the SSDs and tried them one by one, disconnected all peripherals except the mouse and keyboard, checked all BIOS settings, and tried booting using your EFI; it hangs on the screen where OpenCore hands over control to the macOS kernel, stopping at the final message [EXITBS:START] (as shown in post #7). Since I use two monitors, I also tried using just one, but the same error occurs.
If you can help, here are my hardware specifications according to Hardware-Sniffer.
It seems a bit crazy, but after searching the forum, comparing some EFI setups, and following the OpenCore guide, it turns out B550 boards require SSDT-CPUR. After removing it and trying Sonoma, I managed to complete the installation. However, the audio isn't working, and the Vega 8 isn't being recognized. I'll check the post-installation steps to see if I can fix that. Also, one more question: can I update directly to Sequoia from here?
Good to hear you have installed macOS.
Your audio not working is a common issue. As you need to confirm which layout ID you are using (alcid=xx) for your Realtek audio codec. On my B550 systems I use alcid=15, as that was a layout-id that was generated by another Guru here at AMD OS X, for AMD B550 boards that use the Realtek ALCS1200A codec.
You need to make sure that NootedRed.kext is being injected as part of your OpenCore setup for the Graphics to work. You also need to make sure you have allocated more than 512mb of VRAM/UMA to the AMD IGPU in the Bios. As you have 16G of RAM I would recommend you set the UMA value to 2G. You can always increase this value if you find that 2G is not enough, although I wouldn't allocate more than 4G.
Yes, you can update to Sequoia from Sonoma using the Apple Software Update process.
It appears from reviewing the System information report you provided that your motherboard uses the Realtek ALC897 audio codec. So it is very unlikely that alcid=15 will work with your setup.
These are the layout-id's present in AppleALC.kext for the ALC897 codec.
None of the ID's are specifically generated to work with an AMD B550 motherboard, so you will have to try each one, i.e. alcid=11 through to alcid=99 in turn to see if one works with your system.
My audio layout is 11, and when I tried alcid=11 in boot-args it worked.
Now, at certain times, specifically when trying to play YouTube videos, it freezes and then comes back after a few seconds; other times, the background becomes all checkered. I managed to change it to 2GB of video memory, but Vega 8 still doesn't appear, and the Nootred kext doesn't show up in Hackintool. And I can't connect my Apple ID either.
I'm still trying to organize things around here.
So you are now dealing with normal post-installation teething problems.
Hackintool hasn't been updated to include the NootedRed or NootRX kexts in its 'Extensions' tab. Don't know why but this is the same for both AMD graphics kexts. Nothing you or I can do about that.
The Graphics card name not showing in 'About this Mac' is purely cosmetic. It doesn't affect how the system works. It can be ignored.
The YouTube video issue may be caused by your system not working with Digital Rights Management (DRM), which real Mac's provide. There are probably some work arounds available but I don't have one to hand. It could also be down to the browser you are using. Safari, Chrome and FireFox all have their own weaknesses and issues when run on a Hack.
