Hackintosh stuck at Blocked sign
blackrcses
AMD Ryzen 7 7700X
Specs:
Ryzen 7 7700X
Radeon 570
SMbios: MacPro7,1
Post a copy of your EFE folder so we can see what you are using.
The commonest reason for the prohibited 🚫 sign showing is when the USB port used for the macOS installation drive is dropped, once control has been handed to the installation process. Having a UTBMap.kext isn’t the same as having a compatible working USB setup. It is very easy to not include a port or to set a port with the wrong connector type. Both of these can cause the issue you are seeing.
Adding the following boot arguments to your configuration.plist might shed some more light on this issue.
-v keepsyms=1 debug=0x100
Have you used the debug version of OpenCore to generate an OC log that contains the Mmio Whitelist entries for your B650 motherboard? See this OC troubleshooting page for details on how to use DevirtualiseMmio and Target quirk to get the information you need.
Here's my EFI and I also included a log that Opencore gave me after boot. Also I'm on the release version of opencore 1.06 should I change to the debug version?
I will have a look at the EFI folder when I am next at my desk.
The OpenCore log doesn’t show the Mmio devirt entries, so I assume you are not using OpenCore Debug version.
Ok thanks! and yes I am on the release ver of opencore
