GPU Fans always on, any fix?
alliance
33
5700X
Hi,
so I've noticed my RX 6800 always has it's fans spinning, is there anyway for zero rpm to work, just like it does in Windows?
I currently use Whatevergreen and agdpmod=pikera
Is there a safe way for zero rpm to work without the risk of overheating the GPU?
Thanks!
Does your GPU have a slider that allows you to switch between Performance and Silent Mode? Usually found along the top edge of the card if present.
The other option is to create a custom Power Play Table for the GPU. This was a common fix necessary for AMD VEGA 56/64 cards a few years back. See the guide linked below.
It's in silent mode now, but it never stops, unlike in Windows :(
Ah, if there's not a kext that makes it work normally, then I'll leave it, I'm not a fan of running random Chinese apps etc. I really don't like the idea of that.
